Re: Flexible wings 2011
Posted: 01 Apr 2011, 09:58
omg.... it took me a few days, but I started at the start, and read through every single post, looked at every link... and finally, I consider myself worthy of a reply.
First of all, I will openly admit that I am a Redbull fan (consider me biased, whatever, maybe I am). But, I think it's great what they are doing. I am in my last few months of a Mechanical Engineering Degree, and I have to say, in my eyes, from my perspective, what the Redbull aero team are doing, is pure engineering genius.
Even though, they SEEM to be breaking the rules (it certainly looks that way, but it has not been proven beyond all doubt), they are getting away with it.
This is why I appreciate F1 so much, these tricks they use, the innovations, that seems to come out of nowhere, or are so whacky (DDD, F-duct, FFE etc), yet do not fail scrutineering, and give them that extra edge (or cliff...in the case of redbull). It is this stretching and bending of the wording in the rules and regulations, that gives you that extra LITTLE bit to play with, if you find it. And, once you find it, that LITTLE bit extra, sometimes manifests itself into some pretty amazing things.
F1 is all about pushing boundaries, if you seem to be breaking a rule, but it cannot be proven, then I'm all for it, I love to see these things. If the test has to change to prove that you are breaking it... then so be it. I'm all for it, because then (as was the case last year with the wing) the engineers might pull something else out of the hat, to still pass the test. If the test doesn't change, then there is nothing stopping other teams trying to do the same thing, if it really works or helps.
I wonder how many other F1 cars have things, that we cannot see, and are not clearly visible, or noticeable, that also give an advantage, also break the rules, but also manage to circumvent the testing procedure. I wonder how many more Redbull have?
I had a lot more to say, but that's long enough
anyway, that's my opinion, that has been brewing for a few days.... fire away
EDIT:
EDIT:
is it possible that every team is "trying to break the rules and cheat" ? we don't know the answer to that, but it's possible, and RB are the only (or maybe not the only as i mentioned above) ones smart enough, and innovative enough to be getting away with it.If you gona admire RB for engineering a flexy wing, then you should also admit that they are trying to brake the rule and cheat, no?
