Page 4 of 4
Re: Michelin problems at Indy 2005
Posted: 14 Dec 2011, 22:10
by flynfrog
WhiteBlue wrote:
Michelin officially blames special dynamic effects of turn 13 to generate loads far superior to the maximum estimation of their engineers.
What do you think was this special dynamic effect if it wasn't resonance?
how about the increased load that a banked corner places on the outer shoulder of tire? Its amazing how you can read anything to fit your pre drawn conclusion.
Posted: 14 Dec 2011, 22:18
by strad
Gas pressure supports load
Don't start this again...It is not the gas that supports the load and adding pressure doesn't act as increasing the spring rate...at least according to our resident experts.
WB....
Posted: 14 Dec 2011, 22:23
by hardingfv32
How far down the sidewall could one expect the steel band mentioned in the Michelin tire? I have never seen the steel belt extend beyond the thread width.
Does steel have better properties than aramid synthetic fibers? Seems an odd choice where cost is a low priority.
Brian
Posted: 15 Dec 2011, 01:32
by WhiteBlue
The increased load that a banked corner places on the outer shoulder of a tire isn't special at all and would not have been overlooked by Michelin. They knew the track from years ago and they knew the downforce their customer teams produced that year. They knew the speeds probably down to 3-5 kph. They even knew how different cars would use the tyres differently. How could they fail to take something so simple into account in their physical model.
The one thing they did not know and could not foresee was the lateral oscillation which Michelin called bobbing and that occurred on the side wall. That was the only special physical effect.
Posted: 15 Dec 2011, 01:42
by WhiteBlue
strad wrote:Gas pressure supports load
.. It is not the gas that supports the load and adding pressure doesn't act as increasing the spring rate...
Sometimes you hit the nail on the head. Different tyre pressure was never a parameter to the solution of the Indy 2005 problem. Even if we assume that the tyre is a non linear spring damper system the spring rate would not change drastically enough in the small pressure range of an F1 operating window to avoid a resonance if they designed an Eigen frequency into that range.
Posted: 15 Dec 2011, 03:41
by hardingfv32
1) Why the much higher tire pressure used by oval formula cars?
2) I think that turn 13 at Indy had very different requirements than the other 12 (?) turns. What was required for turn 13 was very bad for the other 12. Could it be that Michelin just made a wrong aggressive compromise?
Brian
Posted: 15 Dec 2011, 05:36
by FW17
What caused this lateral oscillation?
Posted: 15 Dec 2011, 06:25
by flynfrog
the fact that corner has way more banking than any other corner in F1 id say that would be a special dynamic situation.
Posted: 15 Dec 2011, 16:16
by WhiteBlue
resonance
Posted: 15 Dec 2011, 16:21
by WhiteBlue
flynfrog wrote:WhiteBlue wrote:flynfrog wrote:how about the increased load that a banked corner places on the outer shoulder of tire? Its amazing how you can read anything to fit your pre drawn conclusion.
Come on! How would that affect a physical model of the dynamic forces? Not at all!! You simply dial in higher forces with more banking. To create an additional new load you have to assume that a new effect was introduced and not a gradual increas of existing loads.
