Re: Pirelli's poor consistancy a reflection of their road ti
Posted: 05 Mar 2011, 21:31
1: Many engineers have commented on the somewhat archaic and arbitrary dimensions of modern F1 tires, and when Michelin was talking to the FIA about taking over the exclusive supply last year one of their requests was that they be allowed to use a more modern construction, similar to what you see in other high performance tires (IE., much shorter sidewall, very different aspect ratio) and larger wheels.Jersey Tom wrote:What is your reasoning behind this statement?Sayshina wrote:I should point out that the Michelins being raced on 911's in endurance events around the world are at least 1000 times closer to your road tires than any F1 tire ever made.
2: High performance road tires, especially on bikes but also cars, have tended over the last 20 or so years to be very similar to what was being raced a few years prior. A good example of that are the multi compound bike tires, that a few years ago were exclusively top end racing animals, and are now considered baseline equipment.
3: A racing 911, in say GT3, will certainly have more power and less mass than it's street counterpart, but for the most part we're talking 10-15% differences. Isn't the downforce on a GT3 measured in the hundreds of pounds? It's not going to be a shocking departure, and it's going to require broadly similar characteristics from the tires. You may go slightly larger or smaller on one end to get different turnin characteristics, you may go slightly more agressive at one end to solve a problem the setup is unable to, but in most racing series you're stuck with many or all of the suspension components, the fundamental stiffness of the chassis, your aerodynamics, and often stock or mostly so engine.
If all you're allowed to do is rip out the stereo, sound proofing, and passenger seat, and all you're allowed to do to the engine is remap it, your tire requirements will follow suit.
4: Once you get off the world stage, not only are bespoke racing tires not the norm, but in many series you're required to use street legal items, often expected to last more than a single weekend.
5: 15 years ago you could make the arguement that an indycar was broadly similar to a F1 car, today there's nothing close. You can make a good arguement that the diesel endurance cars are as much or more of a challenge to develope tires for, but they don't in any way have the same characteristics.
