Posted: 30 Mar 2014, 21:29
I dont have the data, but looking on the % consumption during the race. The ferrari was pretty much equal with mclaren.
What makes you say Mclaren and Williams didn't load the full 100kg? Also, I don't think anyone is burning much fuel on the over-run. I think it would be worth more under acceleration because it doesn't suffer from the electrical losses associated with moving energy from mgu-h to es to mgu-k. With the brake by wire, why would they want to burn fuel on the overrun?Tommy Cookers wrote:today's race suggests that Williams and Mclaren loaded about 92 and 95 kg of fuel respectively, the others the full 100 kg ?
presumably most teams are doing significant mgu-k 'recovery' from engine running
and the above 2 teams are not
From the % stats in the race, I wonder whether williams are underfueling because their car is above the weight limit? Therefore they would have to save a bit more fuel in the race but wouldnt be much quicker than those around them.ringo wrote:I noticed that the ferrari engine is respectively fuel efficient.
The williams seem to be the most fuel efficient.
As for the fuel used, i think all cars will have the full 100kg of fuel in the tank. I don't think they will remove 5kg just to be exact.
the fuel used figures were clearly presented in the TV coverage, even near the end of the racePierce89 wrote:What makes you say Mclaren and Williams didn't load the full 100kg? Also, I don't think anyone is burning much fuel on the over-run. I think it would be worth more under acceleration because it doesn't suffer from the electrical losses associated with moving energy from mgu-h to es to mgu-k. With the brake by wire, why would they want to burn fuel on the overrun?Tommy Cookers wrote:today's race suggests that Williams and Mclaren loaded about 92 and 95 kg of fuel respectively, the others the full 100 kg ?
Most is correct. I did some calcs which showed only Singapore being comfortably over the 2MJ limit, all others being below. The next closest is Abu Dhabi, with approximately 1.8MJ recoverable per lap, a few (including Bahrain) were about 1.5MJ.Tommy Cookers wrote:many (most ?) races will not allow the full desired recovery-to-storage from braking alone (in part as it's limited to 120 kW)
loading the engine to generate electricity (necessarily for storage) is possible whenever the driver doesn't need full torque
it is a pretty race-useful thing to do with fuel (IMO better than leaving some of the 100 kg in the pit)
most are doing it ? (I predicted they all would) but apparently and conspicuously Williams and Mclaren are/did not
maybe they have designed eg their storage system around this concept, and accessed some other beneficial savings ?
IIRC Malaysia is (quite surprisingly as it's rather fast) not a fuel-hungry race ?
It's worth noting that from Australia we learned the Williams drivers often shift at 10500 or there abouts rpm, so it would be expected they use less fuel than the other teams.ringo wrote:The williams seem to be the most fuel efficient.
Was the regulations changed this year, so you can't harvest energy from the MGU-K unless you're braking?xpensive wrote:As the MGU-K is only 120 kW it depends on time and charging efficiency, with 100% efficiency you need is 16.7 sec of braking for 2 MJ, but already that is a lot. According to Brembo, average braking time per lap at Sepang was 15% or about 15 seconds.
But I doubt if the total efficiency is much more than 80%, why you would need at least 20 seconds of braking for 2 MJ.
If the regulations does not stipulate that you can only harvest from the K during braking, clever maps could be generated to have a more progressive power delivery out of corners during acceleration. And of course help to charge the full 2 MJ a lap.xpensive wrote:How should you otherwise harvest energy with the MGU-K and what would be the point?
From Autosportmrluke wrote:From the % stats in the race, I wonder whether williams are underfueling because their car is above the weight limit? Therefore they would have to save a bit more fuel in the race but wouldnt be much quicker than those around them.ringo wrote:I noticed that the ferrari engine is respectively fuel efficient.
Noting the very high trap speeds of the Williams, I bet they are running less DF thus less drag than others. It helps them with their fuel consumption.12:08 Meanwhile, Bottas has confirmed to EDD STRAW that he didn't start the race with all 100 kilograms of allowed fuel on board, as the team was confident of not having any consumption worries.
What do you mean?? They can use 4 MJ a lap. And I'm pretty sure they would be able to use the full 4MJ.dren wrote:But only if you can use the full 2MJ a lap, too.
That's what I thought they are doing too.Holm86 wrote:If the regulations does not stipulate that you can only harvest from the K during braking, clever maps could be generated to have a more progressive power delivery out of corners during acceleration. And of course help to charge the full 2 MJ a lap.xpensive wrote:How should you otherwise harvest energy with the MGU-K and what would be the point?
