Posted: 03 Jul 2014, 22:12
My understanding is that most modern GDI systems operate with stratified charge at lighter loads and lower rpm and operate with homogeneous charge beyond that.
Thanks for the reference. Couldn't find the figure in the restricted copy I downloaded. Perhaps you could post an image?Tommy Cookers wrote:BTW if people Google V Ganesan Internal Combustion Engines
.... Googling dissociation should also get this book at the right pages
they should find Fig 3.6 (page 115 in my copy) showing real engine BTE benefits (from leaning) fall far short of fuel-air theory
and Prof Ganesan's statement .... 'the maximum efficiency is within the lean zone very near the stoichiometric ratio'
No - the maker would have very specific goals for AFR and the dyno work would be a struggle to develop an engine that will function and survive with that AFR.ringo wrote:This discussion is not very novel, since we know a team will simply use the engine bench to play around with ratios to get the best result. I'll just say the engine maker will simply go with whatever air to fuel ratio suits their needs from the engine.
Isn't the mgu-h limited to 120 kw?WilliamsF1 wrote:Merc's secret for drivability control is probably the way the ERS-H works. FIA does not define the power rating of this MGU, Merc probably using a higher rated unit that does a very good job in spooling the turbo and avoid lag.ringo wrote:Switching gears a bit.
The drivability of the different engines to me is very interesting. I haven't seen much discussion on that even though there is ample evidence that some units, like the ferrari have a poorer drivability.
What's going on with the mercedes power unit, that allows it to behave so well on acceleration out of a corner compared to the renault and ferrari?
Other 2 engines are probably having a turbo lag and are using the ERS-K to compensate for this along with ERS-H which causes poor drivability when the turbo kicks in.
No. The MGUK is limited to 120kW, but the MGUH is not restricted.Cold Fussion wrote:Isn't the mgu-h limited to 120 kw?WilliamsF1 wrote:Merc's secret for drivability control is probably the way the ERS-H works. FIA does not define the power rating of this MGU, Merc probably using a higher rated unit that does a very good job in spooling the turbo and avoid lag.ringo wrote:Switching gears a bit.
Oops forgot to edit. It wouldn't make sense. Yes stratified at low load/rpm and homogeneous beyond.gruntguru wrote:My understanding is that most modern GDI systems operate with stratified charge at lighter loads and lower rpm and operate with homogeneous charge beyond that.
How is a simmulation going to tell you more than a real test?gruntguru wrote:I don't think these guys learn much about mixtures on the dyno beyond getting the final trim sorted and perhaps seeing how far the envelope can be pushed in some cases.
What I mean to say is, they pretty much know what they would like to see - what mixtures they would like to be able to run before an engine even goes on the dyno. All courtesy of powerful computer simulations and lots of development with single cylinder engines (on a dyno of course).
Let me remind you what Ringo said.No - the maker would have very specific goals for AFR and the dyno work would be a struggle to develop an engine that will function and survive with that AFR.ringo wrote:This discussion is not very novel, since we know a team will simply use the engine bench to play around with ratios to get the best result. I'll just say the engine maker will simply go with whatever air to fuel ratio suits their needs from the engine.
Most posters clearly had not even considered the possibility of these cars running lambda 1.1 and above.
It seems that MB can do it all thru every lap tho due to their oversized turbine.gruntguru wrote:Not just MB. They all can.
Supposed oversized turbine.djos wrote:It seems that MB can do it all thru every lap tho due to their oversized turbine.gruntguru wrote:Not just MB. They all can.
