Page 46 of 71
Re: Red Bull RB6
Posted: 29 Aug 2010, 21:21
by Rino
With the current testing methods...
Btw Gilgen do u work in RB or something...I mean how can u be so sure in RB6 legality?
It's Adrian Neweys car were talking about... :^o
Re: Flexible wings controversy 2010
Posted: 29 Aug 2010, 21:28
by strad
The cable is for the adjustable front wing...calm down
Re: Red Bull RB6
Posted: 29 Aug 2010, 21:34
by aral
Rino wrote:With the current testing methods...
I read the technical reports on FIA.com!
Posted: 29 Aug 2010, 21:37
by xpensive
I am talking about the crooked carbon-fibre worm that does all the magic, if only people could see the obvious there.
Re: Red Bull RB6
Posted: 29 Aug 2010, 22:18
by Mandrake
All the fuss about a car that didn't even win today's grandprix, nor did it show extraspecial performance this weekend
Posted: 30 Aug 2010, 13:02
by mep
Do you think the current wing deflection tests are still good enough, or do you believe teams are focusing only on getting through scrutineering and then doing other things out on track?
AC: The front wing FIA load is roughly 2.5 times lower than the maximum load you would get at top speed. So there is room to increase the load, but then it is a matter on how to apply the load statically in the garage. It is not easy. But we would be quite happy to increase the load on the wings. We are quite far from the top speed maximum load, so the wing can accept a higher load for sure in terms of the FIA test. There are no issues on that front from our side.
What load to test the wings is he revering to?
Is it now 50kg or 100kg and both sides or just one?
I would like to know the maximum downforce such a wing can produce.
Posted: 30 Aug 2010, 13:06
by n_anirudh
http://www.formula1.com/news/technical/ ... 6/782.html
Interesting that the 100kg load is applied thru the middle sections, rather than the endplates as previously...
Posted: 30 Aug 2010, 13:27
by strad
xpensive wrote:I am talking about the crooked carbon-fibre worm that does all the magic, if only people could see the obvious there.
Yes but theyre talkin about the bit of cable that was seen hanging from the wing ex post wrecko
Re: Red Bull RB6
Posted: 30 Aug 2010, 13:35
by autogyro
Mandrake wrote:All the fuss about a car that didn't even win today's grandprix, nor did it show extraspecial performance this weekend
Surely you mean the Ferrari F10.
Posted: 30 Aug 2010, 15:10
by fausto cedros
james allen wrote wrote:
After the heated debate in Germany and Hungary about the Red Bull front wing flexing to increase front downforce, a new more stringent test was introduced by the FIA. Red Bull passed the test.
The Red Bull wing at Spa featured fewer elements than the Hungary wing and observers say that it did not flex out on track as much as in Budapest. The team says that they have changed nothing in the wing apart from things they would normally do when moving from an ultra high downforce circuit like Hungary to a faster circuit like Spa. However senior composites technicians from the team’s Milton Keynes base, who do not normally attend Grands Prix, were noticed in the paddock, which means that something out of the ordinary was taking place. The theory is that the wing flexes outwards due to a sophisticated layering process of the carbon composite material.[
Posted: 30 Aug 2010, 15:57
by 747heavy
Sorry, but I think what they state on F1.com is incorrect.
The 500N (~50kg) test was not carried out at the endplates.
You can go and check for yourself in the FIA F1 regs (on the FIA website)
if you like.
Posted: 30 Aug 2010, 17:50
by xpensive
I'll be darned, aren't they clever those engineers?
Btw strad, the thing hanging out of the wreck was a cord, not a cable.
Posted: 30 Aug 2010, 21:30
by strad
I'll rewatch but not today...I'm beat
Posted: 30 Aug 2010, 21:34
by forty-two
I see no mechanical reason for the FW flap adjust to include a flying lead. When other teams have changed their nose mid race, I've certainly never seen any "plugging-in" of any connector. I'd always assumed that they must use some kind of edge connector or sprung voltage transfer contacts for this very reason.
So why would a team as technically advanced as RB carry the extra weight of a flying lead arrangement?
Also, if as Ted Kravitz said, Vettel's FW adjuster was no longer functional, how did he notch up at least one fastest-lap?
Seems a bit fishy to me...
Posted: 30 Aug 2010, 21:39
by forty-two
xpensive wrote:Btw strad, the thing hanging out of the wreck was a cord, not a cable.
Pardon my ignorance, but what is your distinction between cord and cable?
