Bill
Bill
Dee wrote:
08 Nov 2025, 17:23
euv2 wrote:
08 Nov 2025, 16:18
08 Nov 2025, 15:57
Surely they go back to the old floor
Sector 2 performance so far, Max-37.625 Tsu - 37.751, Tsu was in free air vs Max who was 1.2s off Russell.
Question is, how much faster is Max vs Tsu in a sector like this? If this is where Max puts 4/5 tenths on Tsunoda in a lap, then Max should switch to the old floor..
All cars were on drs train from p10 to p20
venkyhere
43
best sector2 times in sprint :
NOR - 36.7
PIA - NA as he crashed early when fuel load was high
ANT - 36.7
RUS - 36.9
VER - 37.1
LEC - 37.3
HAM - 37.5
TSU - 37.7
That 0.4 disadvantage remains, expectedly. TSU's time is irrelevant irrespective of what 'experimental setup' he ran, for obvious reasons (2nd redbull driver can't drive difficult car... blah blah).
Without addressing this (more wing or less stiff suspension or ride height or whatever) core issue, it's pointless racing on Sunday. Whether wet or dry, this painful disadvantage will not 'magically go away' by lumping 'hope' on track temp or tyre age or compound delta etc. The car has to undergo some 'fix', even if it makes it worse, that risk has to be taken, because 'nothing to lose' anyway (want to see Redbull live up to their 'gambler' reputation) - otherwise all the excitement for a tight championship finish will be wasted.
For me, even a P4/P5 grid spot is fine in main Q, as long as sector2 is fixed. Without sector2, DRS cannot be used on the pit straight. Top speed will be useless without a good sector2. Only if sector2 is fixed, can the driver make 'moves' with alternate lines (wet or dry) attacking the car in front, into T1 or T4 (the only overtaking spots).
FNTC
FNTC
Both running the low DF rear wing for qualy according to Sky
CjC
CjC
FNTC wrote:
08 Nov 2025, 19:50
Did they run this low DF wing in the sprint?
Just a fan's point of view*
FNTC
FNTC
Max casually catching his own slide in the same spot right behind Oscars crash, after Lando hit the puddle. https://dubz.co/v/638345
FNTC
FNTC
CjC wrote:
08 Nov 2025, 19:56
FNTC wrote:
08 Nov 2025, 19:50
Yes, Max ran it, but they tested the higher DF wing on Yukis car in the sprint race.
Valeo
Valeo
If I understood it correctly, Helmut Marko said they are running the old floor on Max car?
euv2
euv2
FNTC wrote:
08 Nov 2025, 19:50
Also running higher and softer.
Are they even going to make Q3? :?
Beware of T-Rex
08 Nov 2025, 20:09
Q2 too much to ask... :?
Beware of T-Rex
Valeo
Valeo
WTH??
euv2
euv2
Haha, Redbull are lost, they totally messed the car up.
Juzh
161
looool wtf
PierreW
PierreW
What did they do to the car?
I am speechless. Start from the pitlane and change everything.
Emag
Emag
137
What in the world did they change to the car wow. What a disaster.
Developer of F1InsightsHub
