Re: Race start monitoring system
Posted: 16 Oct 2019, 22:04
Apologies for bring back an old thread, but I think this is the home for this question. Especially given the content in this thread.
To summarize, it sounds like jump starts are detected by a combination of things including high speed cameras and "something" in the car (maybe an accelerometer, maybe other sensors). While early speculation in this thread was around grid position timing loops, per car transponders, that was said to not be the case and not part of the system that is actually used. As stated multiple times, the transponder used for T&S is NOT part of the jump start detection.
This begs the question as to why the sporting regulations say a jump start is determined by the transponder in the car? It also says the judgement is made by the transponder (i.e. automated) and not by examination via the stewards?
Per 2019 Sporting Regulations: (bold by me)
Richard
If the info in this thread is correct, why is the process and the sporting regulations so far out of sync from reality? If the current process is "just how it is" and it supported by the teams, then why not just update the sporting regulations?36.13 Either of the penalties under Articles 38.3c) or d) will be imposed on any driver who is judged
to have :
a) Moved before the start signal is given, such judgement being made by an FIA approved
and supplied transponder fitted to each car, or ;
b) Positioned his car on the starting grid in such a way that the transponder is unable to
detect the moment at which the car first moved from its grid position after the start
signal is given.
Richard
