Page 55 of 84
Re: A shameless image thread for the enginephiles
Posted: 10 Feb 2015, 17:11
by poolboy67
i love diesels.
Posted: 18 May 2015, 11:15
by djos
Omg, check this 80's Ferrari powered beast out! It made 1400 Hp on 120-octane super-premium race gasoline.
"Flat-12 Ferrari Boxer block fitted with 4-valve Testarossa heads, topped with a beautifully sculpted and truly massive air-water intercooler mounted directly on top of the block. The intercooler featured 12 super-high-flow electronic injectors spraying furiously into velocity stacks integral to the intercooler. The massive intercooler unit bolted directly to the heads and functioned as a combination intake plenum/intercooler/fuel rail/manifold unit.
The centrifugal blower—salvaged from a gigantic British locomotive engine that apparently no longer Thought It Could—was driven by a 1.5-inch shaft that traversed the length of the engine and was driven off the flywheel via a reversed Allison turbine helicopter gear-reduction unit originally designed to step down turbine velocities to something the main rotor could handle. The FAA required this type of gear reduction to be replaced after even a single emergency auto-rotation power-off landing, guaranteeing availability at fire-sale prices. The blower, looking like a hugely-overgrown Vortech blower sent back in time by The Machines to destroy all human life in 1989, had a five-inch impeller that was capable of gobbling air at the rate of something like 500 pounds per minute, a rate that could probably suck the air out of double-wide in less than 60 seconds
The supercharged 12-cylinder Boxer engine, featuring a lightened flywheel and knife-edged crank, and could rev from the engine’s 1200 RPM idle to the 9K redline in just over a tenth of a second, and had been certified on a Superflow 901 engine dyno to make 1400 horsepower on 120-octane gasoline at 60psi boost. The short-stroke 3.2-inch bore engine was upgraded with a billet Crower crankshaft, extra-long Crower rods, custom forged pistons, and was managed by a Haltech F3 EFI controller and a Firepower direct-fire 12-coil ignition. According to Norwood, each 24-valve head was carefully flowed and mildly ported for optimum forced breathing."
In this
Full text here:
http://www.bobnorwood.com/un-salted%20f ... -power.htm
Posted: 23 May 2015, 21:20
by nokivasara
How about the incredibly successful Ford BDA?
Beatiful song @ full tilt, 10 000 rpm...
They are still available but started out back in the 60's. The most powerful I know (BDG) of has about 300hp, pretty amazing from a 2-litre n/a lump :shock:
Posted: 23 May 2015, 22:54
by RicerDude
Alfa's 3.5 litre V10 found in the plain bonkers 164 procar from the 90's. It was originally destined to power the Ligier JS31 for 1988.
Posted: 06 Jun 2015, 16:42
by stefan_
Posted: 10 Feb 2017, 02:06
by flynfrog
Lets revive this thread it is the off season after all
I give you the Pontiac 4 cam V8. Sequential fuel injection all started in 1963
Hot Rod mag article
http://www.wallaceracing.com/ohc-v8-cover.html
Posted: 10 Feb 2017, 02:51
by donskar
This thread is an old favorite. Reminds me that Xpensive is gone. But NOT forgotten.
Posted: 10 Feb 2017, 03:26
by roon
Toyota TRD-BIZ001
Twin turbo (sequential) Hayabusa built for standing-mile record.
Posted: 10 Feb 2017, 06:53
by roon
RicerDude wrote:Alfa's 3.5 litre V10 found in the plain bonkers 164 procar from the 90's. It was originally destined to power the Ligier JS31 for 1988.
http://www.berlinasportivo.com/features ... 4_eng3.jpg
http://assets.blog.hemmings.com/wp-cont ... ar%202.jpg
https://s-media-cache-ak0.pinimg.com/73 ... 04531f.jpg
That last pic makes me wonder: where is the oil filter on more recent F1 engines, and what do they look like?
Posted: 10 Feb 2017, 17:33
by flynfrog
Posted: 16 Feb 2017, 14:21
by flynfrog
Here is the Clisby F1 engine. Built but a rule change meant it never raced.
http://www.theadelaidetimes.com.au/index.php?p=1_46
Posted: 17 Feb 2017, 06:58
by gruntguru
Interesting engine. It seems to have two spark plugs per cylinder so probably very high B/S ratio. Wide Vee angle too, 90 or 120 perhaps?
Posted: 17 Feb 2017, 07:03
by wuzak
gruntguru wrote:Interesting engine. It seems to have two spark plugs per cylinder so probably very high B/S ratio. Wide Vee angle too, 90 or 120 perhaps?
Interesting indeed.
I can't recall for certain, but I don't think any of the 1.5l engines from the 1960-1965 formula were supercharged for the 1966 formula. Renault, of course, took up the supercharged rules with their turbo in 1977.
I wonder that if any had if they would have been competitive with the V8s and V12s.
Posted: 17 Feb 2017, 15:21
by flynfrog
I dug up some more info. Seems like this guy was pretty well know in Australasia not so much out side of there.
http://www.collingrovehillclimb.com.au/haroldclisby/
There is also a 24 Cylinder 2 stroke he built.
Posted: 17 Feb 2017, 20:24
by bill shoe
Also may be related to DOHC config with total of 2 valves/cyl. Once you maximize valve diameters you end up needing to locate the plug off to one side or the other, so might as well do both sides.
