Re: Proposed 2017 F1 Aerodynamic Changes
Posted: 23 Dec 2016, 03:58
I don't think the aero is more efficient. The floor changes will be, but the lower rear wing won't be.
But they dont push tire turbulence away from the rear wing. They prevent spanwise flow migration in turns. Which is "stabilizing" the flow. I have a beef with the tire turbulence bs.godlameroso wrote:Sails do help to stabilize flow.
That lower rear wing also has a MUCH better aspect ratio. The front wing will also have a better aspect ratio.FPV GTHO wrote:I don't think the aero is more efficient. The floor changes will be, but the lower rear wing won't be.
My understanding that that any potential issues with turbulent air from the bodywork, potentially causing problems for the lower rear wings, should be more than off-set by the increased width (it is my understanding that a wider wing that needs less angle of attack to achieve a given level of downforce produces less drag, relative to a narrower wing that needs to run a higher AOA to get the same DF levels), as well as better interaction with the diffuser.FPV GTHO wrote:I don't think the aero is more efficient. The floor changes will be, but the lower rear wing won't be.
Yes, I think there is no question, that we will see higher DF levels.zztopless wrote:My understanding that that any potential issues with turbulent air from the bodywork, potentially causing problems for the lower rear wings, should be more than off-set by the increased width (it is my understanding that a wider wing that needs less angle of attack to achieve a given level of downforce produces less drag, relative to a narrower wing that needs to run a higher AOA to get the same DF levels), as well as better interaction with the diffuser.FPV GTHO wrote:I don't think the aero is more efficient. The floor changes will be, but the lower rear wing won't be.
And outside of isolation you also have much more area which can be dedicated entirely to working aero compared to that which you need simply for packaging the driver, engine, radiators, thermal management, etc.Pierce89 wrote:That lower rear wing also has a MUCH better aspect ratio. The front wing will also have a better aspect ratio.FPV GTHO wrote:I don't think the aero is more efficient. The floor changes will be, but the lower rear wing won't be.
In isolation, sure, one point of downforce will be more efficient on a wider wing than a narrow wing. But if you put the same load on a low wing as a high wing, the high wing is in cleaner air and also applies more load through the chassis through a larger leverage action. There's also the consideration that chasing downforce gains through the wings is less efficient than gains through the floor.zztopless wrote:My understanding that that any potential issues with turbulent air from the bodywork, potentially causing problems for the lower rear wings, should be more than off-set by the increased width (it is my understanding that a wider wing that needs less angle of attack to achieve a given level of downforce produces less drag, relative to a narrower wing that needs to run a higher AOA to get the same DF levels), as well as better interaction with the diffuser.FPV GTHO wrote:I don't think the aero is more efficient. The floor changes will be, but the lower rear wing won't be.
Also, when you think about how good the teams have gotten at controlling the airflow with the intricate front wings and add in the much larger barge boards, it makes me winder if turbulent air form the bodywork will even be an issue (especially for the top teams)...
The only force higher wing could increase through leverage is drag if you look at the mounting and how the forces are going through the wing to the chassis. In reality, the whole leverage thing doesn't matter anyways because leverage can't be used to obtain higher overall downforce. All it can do is change the balance authority between the front and rear.FPV GTHO wrote:In isolation, sure, one point of downforce will be more efficient on a wider wing than a narrow wing. But if you put the same load on a low wing as a high wing, the high wing is in cleaner air and also applies more load through the chassis through a larger leverage action. There's also the consideration that chasing downforce gains through the wings is less efficient than gains through the floor.zztopless wrote:My understanding that that any potential issues with turbulent air from the bodywork, potentially causing problems for the lower rear wings, should be more than off-set by the increased width (it is my understanding that a wider wing that needs less angle of attack to achieve a given level of downforce produces less drag, relative to a narrower wing that needs to run a higher AOA to get the same DF levels), as well as better interaction with the diffuser.FPV GTHO wrote:I don't think the aero is more efficient. The floor changes will be, but the lower rear wing won't be.
DUDE, I said you can't increase over all DF or efficiency through leverage, as the leverage from the other wing will always cancel it out if you try to do it on both ends. Also.any "leverage induced" df you get on one end take df off the other end.FPV GTHO wrote:If it wasn't giving more downforce, it wouldn't be changing the balance.
I think you're both talking about the same thing. Correct me if I'm wrong. FPV, you're saying that the higher mounted rear wing imparts a greater total force per a given downforce 'point' due to a greater lever arm action upon the rear axle. Pierce89, you're saying the only extra force to be found on a high-mount rear wing will be from drag (operating longitudinaly i.e. a backward force as opposed to the vertical, downforce).Pierce89 wrote:The only force higher wing could increase through leverage is drag if you look at the mounting and how the forces are going through the wing to the chassis. In reality, the whole leverage thing doesn't matter anyways because leverage can't be used to obtain higher overall downforce. All it can do is change the balance authority between the front and rear.
There is definitely the possibility to exploit this area, especially given the wider floor and higher possibility for undercut or using ducts that pass through the side pod to enhance the potential of this area.I think the slotted floors (in front of the rear wheel) are a small but underrated 2016 development feature.
Anyone know if the impact of the wider floor + unchanged side pod width will increase the efficacy of slotted/serrated floors?
