Page 592 of 1336
Re: Honda Power Unit
Posted: 27 May 2017, 20:14
by makecry
Not sure what to say honestly. I just feel bad for Alonso, Peter Prod and the engineers and mechanics in the McLaren garage and back in the factory.
Didn't they just make reliability fixes to the MGU-H that would have solved all of the inherent issues?
Posted: 27 May 2017, 20:36
by SameSame
makecry wrote: ↑27 May 2017, 20:14
Hasegawa mentions in the article that they though they solved the issue with the update.
I wonder why they don't change the entire PU if they are starting last in anyway?
Posted: 27 May 2017, 21:40
by PlatinumZealot
Friction when they turn the shaft when before it was whole sale seizure the entire thing. Could it be lubrucant related, shaft or bearings, housing stifness? Any educated guesses anyone?
Posted: 27 May 2017, 21:54
by MrPotatoHead
PlatinumZealot wrote: ↑27 May 2017, 21:40
Usually when you feel friction on a turbo shaft it's either the bearings are damaged and you are feeling it or one of the wheels is touching its housing - usually from bearings that are worn.
Posted: 27 May 2017, 22:14
by Craigy
MrPotatoHead wrote: ↑27 May 2017, 21:54
I think the translation should have said ”spun bearing" as in, one that's already broken.
Posted: 27 May 2017, 22:18
by MrPotatoHead
Craigy wrote: ↑27 May 2017, 22:14
Is the Japanese version available? I'll ask one of the Japanese guys I work with tomorrow.
But turbo bearings can't "spin" like engine journal bearings can as they are designed to rotate.
Posted: 28 May 2017, 23:12
by asinghkakar
Honda is still using MM injectors currently running at 400 bar pressure. They will now be using Bosch injectors either 250 or 500 bar depending on what they choose, injectors from the same family are used by Mercedes with 500 bar pressure
Posted: 29 May 2017, 00:39
by PlatinumZealot
Ok. Good info
Posted: 29 May 2017, 02:43
by gruntguru
MrPotatoHead wrote: ↑27 May 2017, 22:18
The F1 turbos would all be using rolling element bearings surely?
Posted: 29 May 2017, 02:46
by MrPotatoHead
gruntguru wrote: ↑29 May 2017, 02:43
They are using ball bearing cartridges for sure.
Posted: 29 May 2017, 11:07
by bigblue
So why the switch from MM to Bosch injectors ? By the way are injectors so specialised that someone like Honda would not make their own ?
Posted: 29 May 2017, 15:19
by godlameroso
OEM injectors for Honda are made by Keihin, which I believe is a Honda subsidiary, in the same manner as Modulo which makes shock absorbers for Honda.
Maybe there's some intellectual property that MM is protecting. The performance of the fuel injectors is critical beyond F1. And as the aluminum soda can paint business has shown, the Japanese have no problems exploiting intellectual property for their own ends. Human nature I suppose.
Posted: 29 May 2017, 20:37
by PlatinumZealot
I think that is overcomplicating it. Honda simply has to sign some sort of IP protection agreement and purchase the Injectors from Marrelli and that should cover it. Marelli can even seal their injectors to prevent Honda from opening. I don't think Honda as a global company is desperate to copy anyone's designs. There just isn't much to gain but lawsuits.
Posted: 29 May 2017, 23:35
by tom101
PlatinumZealot wrote: ↑29 May 2017, 20:37
that would be the faster, and efficient way. But honda may want to rediscover technology already discovered. And that takes time and money
Posted: 30 May 2017, 14:17
by MrPotatoHead
I very much agree with you here.
Injectors are one of those things that are far more complex than it may seem on the surface.
Getting the balance right of the electronic side vs the mechanical side to get the dynamic behaviour needed throughout their duty cycle and even under differing temperatures is very complex. This is one of those instances where you can't beat someone at their own game.
Although I am surprised they aren't using injectors from "a Japanese manufacturer".
But remember - depending on it's implementation the TJI system could be using standard DI injectors.
