Page 597 of 1331
Re: Honda Power Unit
Posted: 04 Jun 2017, 21:19
by etusch
GoranF1 wrote:
04 Jun 2017, 18:20
Sasha wrote:
04 Jun 2017, 17:18
Bearings not the problem.
Looks like by Hasegawa words update is coming to Canada or race after that.
Is that the big update? Do you have the info?
Hasegawa didn't mention vibration. I wonder if they solve it and of course consumption.
If coming update brings more reliability, lower consumption and vibration issues solved, it will be reasonably good update. And also he said they found a bit performance. I hope it will not be less than spain's 10 kw
Posted: 04 Jun 2017, 21:42
by stevesingo
Sasha wrote:
04 Jun 2017, 17:18
Heat distortion of the turbine?
Posted: 04 Jun 2017, 22:48
by godlameroso
Intake and exhaust tuning, a new fuel injection system, new spark plugs, new hydraulic pumps for the engine, and further mapping tweaks, I'm sure there's another 10kW hiding in there. These things always evolve like that, just when you think there are no more gains to be made you go and prove yourself wrong.
I imagine even if the turbomachinery is very efficient, and the switching and control electronics are also top of the line and incredibly efficient, there is a lot to be gained from developing how the power unit is integrated via the control electronics. That's probably why they speak so much about mapping, they realize there is another few tenths left in optimizing MGU-H to MGU-K to ES to Ancillaries to ICE interaction to maximize power mileage and torque demand.
The storage medium ie the battery allows energy to flow to and from all these systems, which in one way or another are all physically linked.
Posted: 05 Jun 2017, 01:23
by Sasha
Not the major upgrade but with so many problems with the whole PU package, minor upgrades are big.
Posted: 05 Jun 2017, 04:45
by wuzak
godlameroso wrote:
04 Jun 2017, 22:48
10 down, 70 to go?
Posted: 05 Jun 2017, 05:15
by godlameroso
wuzak wrote:
05 Jun 2017, 04:45
godlameroso wrote:
04 Jun 2017, 22:48
10 down, 70 to go?
20 if you count the Spain update, so 60 to go, almost at Renault pace now maybe 20kW off.
Posted: 05 Jun 2017, 07:13
by PlatinumZealot
Sasha wrote:
04 Jun 2017, 17:18
Go on...
Posted: 05 Jun 2017, 07:41
by j.yank
wuzak wrote:
05 Jun 2017, 04:45
godlameroso wrote:
04 Jun 2017, 22:48
10 down, 70 to go?
kW or hp?
Posted: 05 Jun 2017, 08:04
by restless
05 Jun 2017, 07:13
Sasha wrote:
04 Jun 2017, 17:18
Go on...
Maybe this long shaft starts bending? causing wear/problems
TC&MGU-H being 1 package seems like not very good decision reliability wise
Posted: 05 Jun 2017, 09:42
by kasio
05 Jun 2017, 07:13
Sasha wrote:
04 Jun 2017, 17:18
Go on...
Especially after reading interviews "bearing is the problem"
Posted: 05 Jun 2017, 11:20
by restless
We know that bearings fail, but don't know why... so problem might be elsewhere, bearings just the first to fail
Posted: 05 Jun 2017, 14:44
by kasio
restless wrote:
05 Jun 2017, 11:20
Its always as that but most of the time You just need more strength!
Posted: 05 Jun 2017, 14:48
by restless
That after so many fails, Honda doesn't use best/strongest bearings available is doubtful
Obviously, something is shattering the bearings... either vibrations are not completely eliminated, or something else could be in play
Posted: 05 Jun 2017, 14:52
by kasio
restless wrote:
05 Jun 2017, 14:48
But if You are checking bearing with hand... so only indication about failure is bearing itself (not the other thing).
In genera if "other" cause is known then You could use that for indication that bearing will fail.
Posted: 05 Jun 2017, 16:20
by etusch
restless wrote:
05 Jun 2017, 14:48
They are forcing limits for 5 race and five weekend's FP sessions long life parts with most possible lightness. So this is not just strongest part issue. I don't think anybody can produce directly and in the first try a product with metioned working life fitting Honda design, same lightness and same size. İf it is not same size, it is already wrong part and if it is heavier it's out of concept. Saying just it is not best quality or it is not strong is not true. Who knows maybe it is just lubrication caused issue occurs on bearing.
