Page 7 of 8
Posted: 11 Mar 2006, 12:55
by acer
I noticed that the nosecone in wider on the R24.....compared to the MP4-19...mclaren's is smaller....usually seen in 2004..and it's back again in 2006 :roll:
Posted: 12 Mar 2006, 02:37
by m3_lover
http://www.formula1.com/race/technical_ ... 1/248.html
Acer click on that link, second picture, it explains why they changed the nose
Posted: 16 Mar 2006, 12:47
by ginsu
Does anybody know what this device on the end of the camshaft of the R26 engine is? It's on the exhaust camshaft. I guess it could be a cam position sensor, but I'm not entirely sure. It looks like it could be hydraulic because it's a little bit like a snail shape. Jeez, do you think six bolts is enough?
Posted: 16 Mar 2006, 12:53
by axle
That is odd...almost like it's got a cam controlling motor for say VVTi...when they don't have cams!
Pressure or heat sensor?
Posted: 16 Mar 2006, 12:56
by ginsu
What do you mean 'they don't have cams'? Of course they have cams.
Posted: 16 Mar 2006, 12:57
by axle
Oh bugger...I thought they were hydraulicly actuated in and out? Which allows for the hat stand rpms?
Are they not then?
Posted: 16 Mar 2006, 13:33
by zac510
I believe it is an oil scavenge pump.
Posted: 16 Mar 2006, 14:05
by ginsu
No. F1 engines have pretty standard looking camshafts. The valves are buried under pistons for the pneumatic valvetrain. The camshaft operates on a finger follower that directly acts on this piston.
Posted: 16 Mar 2006, 14:08
by ginsu
zac510 wrote:I believe it is an oil scavenge pump.
That sounds right. It could be driven directly by the end of the camshaft. Since the oil might pool near the bottom of the head because of the V-angle. I know it's very important to keep all the oil circulating all the time, no pools should build anywhere in the engine.
Posted: 16 Mar 2006, 14:26
by axle
ginsu wrote:No. F1 engines have pretty standard looking camshafts. The valves are buried under pistons for the pneumatic valvetrain. The camshaft operates on a finger follower that directly acts on this piston.
Seen this now http://scarbsf1.com/valves.html - whoops :D
Something similar to the Lotus engine on a dyno with an electromagnetic valve train system that I saw years ago will hopefully replace the cams completely...eventually...thus helping their evolution into modern mass produced engines.
/End of Hijack :)
Posted: 16 Mar 2006, 14:53
by manchild
That Renault's camless project from scarbs site was never applied in F1.
Here you have pics of F1 cams;
:arrow: viewtopic.php?t=1670&start=0
Posted: 27 Mar 2006, 11:49
by manchild
Some nice pics of R26
Posted: 27 Mar 2006, 12:16
by Scuderia_Russ
You didn't have to post everyone of them again Ranger, think of the poor soles on dial up!! Classy pibs BTW Manchild.
Posted: 03 Apr 2006, 20:06
by benjabulle
I've just added pics of the R26 in my Renault section, you already know some of them as they're Renault media photos but maybe you did not see the focus on certain parts of the technical drawings, that's here :
http://www.gurneyflap.com/formula1renault.html
Posted: 03 Apr 2006, 23:08
by luisandregg
benjabulle wrote:I've just added pics of the R26 in my Renault section, you already know some of them as they're Renault media photos but maybe you did not see the focus on certain parts of the technical drawings, that's here :
I got this picture from your R26 section and I'm wondering how this mono spring rear suspension works. Is there a torsion bar inside each rocker as well? So what's that central spring for???
Thank you!
