Re: McLaren F1 successor
Posted: 09 Nov 2020, 03:45
It doesn’t need to as the diffuser fills the space, it can be horizontal. It becomes all about the volume of the diffuser space.Cold Fussion wrote: ↑04 Jan 2021, 12:11Presumably after the suction point, the diffuser angle can no longer exceed the standard critical angle?
It will certainly be interesting to see how this tech transfers to the real worldJust_a_fan wrote: ↑18 Feb 2021, 10:28I'm looking forward to seeing this car hit the road. I think the comparison tests that the journos will undoubtedly do will be interesting. Chris Harris driving this back to back with the usual suspects from Ferrari, Porsche and McLaren should be a great watch.![]()
Murray stated that switching to "high downforce mode" instantly gives a 50% increase in downforce. Which is quite impressive. As you say, it doesn't work like the race car did because you can't seal a road car to the road. But the fan pulls air from the stagnation zone in the diffuser and just makes it work better. But there's also a low drag mode that gives a 12.5% reduction in drag. Now that's a real world application that would pay dividends across the board. Imagine if we could reduce the drag of every car on the road today by 12.5%. That would be a big saving in fuel and thus emissions.the EDGE wrote: ↑18 Feb 2021, 10:44From what I understand the fans don’t increase the downforce per se, like the F1 BT46 did, but works to remove the boundary layer from the diffuser to increase low-speed downforce giving the effect a much wider working range, or operating in reverse to reduce high-speed drag
Yes but you don’t get air stagnation and separation at high speeds, only low speedsJust_a_fan wrote: ↑18 Feb 2021, 11:58Murray stated that switching to "high downforce mode" instantly gives a 50% increase in downforce. Which is quite impressive. As you say, it doesn't work like the race car did because you can't seal a road car to the road. But the fan pulls air from the stagnation zone in the diffuser and just makes it work better. But there's also a low drag mode that gives a 12.5% reduction in drag. Now that's a real world application that would pay dividends across the board. Imagine if we could reduce the drag of every car on the road today by 12.5%. That would be a big saving in fuel and thus emissions.the EDGE wrote: ↑18 Feb 2021, 10:44From what I understand the fans don’t increase the downforce per se, like the F1 BT46 did, but works to remove the boundary layer from the diffuser to increase low-speed downforce giving the effect a much wider working range, or operating in reverse to reduce high-speed drag
I think it's a great piece of engineering that should give a nudge to other manufacturers to do properly clever stuff.
No, on a heavily reflex diffuser such as fitted to the T.50, you get separation at all speeds because the change in direction is too big for the air to follow it naturally. The fan works against that to remove the dirty air in the reflex section and make the diffuser work better at all speeds. There's a nice little video earlier in the thread where Murray shows this on a white board.the EDGE wrote: ↑18 Feb 2021, 12:14Yes but you don’t get air stagnation and separation at high speeds, only low speedsJust_a_fan wrote: ↑18 Feb 2021, 11:58Murray stated that switching to "high downforce mode" instantly gives a 50% increase in downforce. Which is quite impressive. As you say, it doesn't work like the race car did because you can't seal a road car to the road. But the fan pulls air from the stagnation zone in the diffuser and just makes it work better. But there's also a low drag mode that gives a 12.5% reduction in drag. Now that's a real world application that would pay dividends across the board. Imagine if we could reduce the drag of every car on the road today by 12.5%. That would be a big saving in fuel and thus emissions.the EDGE wrote: ↑18 Feb 2021, 10:44From what I understand the fans don’t increase the downforce per se, like the F1 BT46 did, but works to remove the boundary layer from the diffuser to increase low-speed downforce giving the effect a much wider working range, or operating in reverse to reduce high-speed drag
The exhaust blow diffusers added energy to the stream to increase its effectiveness where this effectively removes air from the stream helping stay attached so increases effectiveness
