Re: 2014-2020 Formula One 1.6l V6 turbo engine formula
Posted: 03 Apr 2018, 07:54
I think Mercedes is close to those numbers in self sustaining mode ie no ES draw.
The turbine isn't able to extract 120kW from the exhaust, if it were there would be little need to made energy around a lap and they PU would never de-rate.godlameroso wrote: ↑02 Apr 2018, 23:24There's a rising fuel rate until 10,500 rpm, I don't think they run the same boost at all RPM's nor do I believe they run constant fuel rate, nor do I think MGU-H works all that much in motor mode. The MGU-H only works to kick start the turbo, ideal boost for a given engine speed could be achieved with as little as 30kW from the MGU-H, the exhaust energy does the bulk of the work. At peak engine torque there's easily 120kw for the turbine in the form of exhaust energy. Turbos are positive feedback devices, the more energy you put in the turbine, the more boost you make which gives you even more turbine energy.
Hmm clearly these cars have blow off valves, I wonder if the boost is sent to the atmosphere or re-introduced into the air box.
That all seems very reasonable.Tommy Cookers wrote: ↑02 Apr 2018, 23:43imo
shifting eg upshifts is done by timed defueling for c.20 milliseconds to detorque the dogs for the shift
the K is for c.20 milliseconds at full generation (demand) to contribute the best it can to slowing the PU to speed the shift
similarly for downshifts the K is at full motoring demand to contribute its bit to speed up the PU
the fuel is cut for milliseconds to detorque the dogs and then brought back in to increase the PU rpm
the fuel cutting and restoration timing pattern for downshifts will be different to the pattern for upshifts
the K response is about as quick as the ICE's
if the K was not energised the shifts would be slower as its inertia would be parasitic
they can’t vent to atmosphere, it’s against the law. The Honda has a clearly visible duct from a valve on the plenum back into the inlet tract.godlameroso wrote: ↑02 Apr 2018, 23:24
The turbine has to extract enough to drive the compressor as well as providing power to the MGU-H. At 120kW they would definitely de-rate. I suspect it is rather more, maybe 150, 90 to the compressor and 60 to the MGU-HBlaze1 wrote: ↑03 Apr 2018, 08:17The turbine isn't able to extract 120kW from the exhaust, if it were there would be little need to made energy around a lap and they PU would never de-rate.godlameroso wrote: ↑02 Apr 2018, 23:24There's a rising fuel rate until 10,500 rpm, I don't think they run the same boost at all RPM's nor do I believe they run constant fuel rate, nor do I think MGU-H works all that much in motor mode. The MGU-H only works to kick start the turbo, ideal boost for a given engine speed could be achieved with as little as 30kW from the MGU-H, the exhaust energy does the bulk of the work. At peak engine torque there's easily 120kw for the turbine in the form of exhaust energy. Turbos are positive feedback devices, the more energy you put in the turbine, the more boost you make which gives you even more turbine energy.
Big difference between 120kw for the turbine to power the compressor and 120kw on top of that for harvesting. I'm not suggesting that at all.Blaze1 wrote: ↑03 Apr 2018, 08:17The turbine isn't able to extract 120kW from the exhaust, if it were there would be little need to made energy around a lap and they PU would never de-rate.godlameroso wrote: ↑02 Apr 2018, 23:24There's a rising fuel rate until 10,500 rpm, I don't think they run the same boost at all RPM's nor do I believe they run constant fuel rate, nor do I think MGU-H works all that much in motor mode. The MGU-H only works to kick start the turbo, ideal boost for a given engine speed could be achieved with as little as 30kW from the MGU-H, the exhaust energy does the bulk of the work. At peak engine torque there's easily 120kw for the turbine in the form of exhaust energy. Turbos are positive feedback devices, the more energy you put in the turbine, the more boost you make which gives you even more turbine energy.
Thanks. I was only thinking of the energy harvested minus that used to power the compressor.godlameroso wrote: ↑03 Apr 2018, 10:46Big difference between 120kw for the turbine to power the compressor and 120kw on top of that for harvesting. I'm not suggesting that at all.
I understand breather gases but I don't see where in the regulations it says 'no venting compressor air to atmosphere.'henry wrote: ↑03 Apr 2018, 09:18they can’t vent to atmosphere, it’s against the law. The Honda has a clearly visible duct from a valve on the plenum back into the inlet tract.godlameroso wrote: ↑02 Apr 2018, 23:24
godlameroso wrote: ↑03 Apr 2018, 11:03I understand breather gases but I don't see where in the regulations it says 'no venting compressor air to atmosphere.'henry wrote: ↑03 Apr 2018, 09:18they can’t vent to atmosphere, it’s against the law. The Honda has a clearly visible duct from a valve on the plenum back into the inlet tract.godlameroso wrote: ↑02 Apr 2018, 23:24
5.8.1 With the exception of incidental leakage through joints (either into or out of the system), all (and only) the fluids entering the compressor inlet and the fuel injectors must exit from the engine exhaust system.
In the end you were bound to be right.Tommy Cookers wrote: ↑03 Apr 2018, 14:34
upshifting gives a rev drop of c.16%
so fuel charge/cycle will rise 16% and air charge/cycle must rise 16% to maintain lambda
so the new absolute 'boost' pressure should be 16% higher
this is roughly equivalent to a required H rpm increase of c. 8%
fwiw my guess (from a bit of experience)
the electromagnetic time constant of the H is regardable as 20 msec bare and 40 msec incl inertias eg turbine and compressor
ie it can accelerate (in vacuum) in 40 mSec to 63% of any step change in demanded rpm
so 8% change in rpm in 20 mSec seems not implausible even with the high and strongly rpm-related compressor loads
it now seems to me that with DI the ICE torque turndown and turnup can be a few msec ('1 rev')
iirc the time window when 2 gears load path components are in position simultaneously is 4 msec ('1 rev')
the time constant of ICE/K rpm is maybe 30 msec ie16% rpm turndown in 10 msec seems possible
Some great info in that post Tommy.Tommy Cookers wrote: ↑03 Apr 2018, 14:34fwiw my guess (from a bit of experience)
the electromagnetic time constant of the H is regardable as 20 msec bare and 40 msec incl inertias eg turbine and compressor ie it can accelerate (in vacuum) in 40 mSec to 63% of any step change in demanded rpm so 8% change in rpm in 20 mSec seems not implausible even with the high and strongly rpm-related compressor loads
