Page 609 of 668
Re: 2014-2020 Formula One 1.6l V6 turbo engine formula
Posted: 05 Apr 2018, 10:40
by johnny comelately
henry wrote:
05 Apr 2018, 10:35
johnny comelately wrote:
05 Apr 2018, 09:35
henry wrote:
05 Apr 2018, 09:25
We’ve discussed the effect on compressor inertia, or at least the whole assembly. Depending on what you think the compressor power is the split second (20 millisecond) might reduce the speed by 5% when you need it to go up to maintain constant lambda. Whether that is significant I don’t know, but it has to happen.
what about the role of the plenum?
Good point, The objective, to maintain lambda on upshift, would be to do everything possible to increase pressure, so maybe they close the throttles. On downshift they might dump from the plenum to the compressor intake.
I don’t know. What do you think?
I dont.
This mini subject feels like a trip to Canadia via Jo'burg :wink:
I emailed the FIA to get clarification re pop-off valve, so 2020 I can tell you.
makes sense to dump in plenum like an oil pump relief.
Posted: 05 Apr 2018, 10:42
henry wrote:
05 Apr 2018, 10:35
05 Apr 2018, 09:35
henry wrote:
05 Apr 2018, 09:25
Close the throttle !!!???...am I misssing something here???
Posted: 05 Apr 2018, 10:48
by J.A.W.
henry wrote:
05 Apr 2018, 10:37
godlameroso wrote:
05 Apr 2018, 05:43
The turbo also harvests electrical energy?
A pedant wouldn’t say so.
What usage condition are you referring to?
Turbo-machinery function vis a vis the electrickery drive - generating, or parasiting - power?
Posted: 05 Apr 2018, 10:52
by J.A.W.
05 Apr 2018, 10:42
henry wrote:
05 Apr 2018, 10:35
05 Apr 2018, 09:35
Perhaps by 'close the throttle' Henry means a split second 'flutter' - to create a (useful?) pressure pulse..
Posted: 05 Apr 2018, 11:01
J.A.W. wrote:
05 Apr 2018, 10:52
05 Apr 2018, 10:42
henry wrote:
05 Apr 2018, 10:35
I got nothing (to this psychodelica stuff) :wink:
Posted: 05 Apr 2018, 11:06
by J.A.W.
But Johhny, you do know how an energised gas column can be used to move things.. in a gun, or a 2T pipe..
Posted: 05 Apr 2018, 11:13
J.A.W. wrote:
05 Apr 2018, 11:06
yep, just cant connect these particular dots. looking forward to class though.
might be an idea to discuss the best spud gun stories....
Posted: 05 Apr 2018, 21:01
Are there humidity sensors used on these engines?
Does anyone know the layout of the sensors for temp, maf (what type?), map etc and who supplies them?
Posted: 08 Apr 2018, 00:03
by godlameroso
I'm sure more data is more better. The trick I guess is avoiding the downsides to the different sensor types, and more importantly getting them all to communicate, with the goal being higher resolution as a whole while accounting for all the different parameters. One could argue that MAP sensor with good tuning is more than sufficient, and it is for your average tin can Flintstone mobile. There's just too many parameters that need to be just right to get the most out of your fire cocktail that you'd essentially be chopping your legs off going the simple route.
Posted: 08 Apr 2018, 02:25
by wuzak
05 Apr 2018, 10:40
henry wrote:
05 Apr 2018, 10:35
05 Apr 2018, 09:35
I dont.
Surely any pop-off valve dumps into the exhaust?
If it goes into the plenum, the whole purpose of the pop-off valve is defeated.
Posted: 08 Apr 2018, 12:58
by hurril
wuzak wrote:
08 Apr 2018, 02:25
05 Apr 2018, 10:40
henry wrote:
05 Apr 2018, 10:35
I dont.
It goes in the airbox.
Posted: 08 Apr 2018, 15:07
by henry
wuzak wrote:
08 Apr 2018, 02:25
05 Apr 2018, 10:40
henry wrote:
05 Apr 2018, 10:35
I dont.
I think you misread, I said “out of” not “into”. From high pressure to low.
Posted: 08 Apr 2018, 22:12
by godlameroso
I wonder if it's possible to combine a map sensor that also has the function of an AF sensor/humidity/temp/etc sensor. From the looks of it Renault has such an assembly integrated into their VLIM system. Sensors and the type used are incredibly important especially from an engine performance stand point, and no one seems to care about boring ol' sensors. Pressure sensors in the cylinders, probably integrated in the injectors and spark plug/flame chamber. Without these sensors your injectors are whizzing in the dark.
Posted: 08 Apr 2018, 22:36
by Xwang
Is it possible to use oil to moisten the air filter?
Posted: 09 Apr 2018, 05:56
by godlameroso
What about exhaust sensors, do they only use a wideband O2 sensor? Do they try to sense other exhaust products? NOx tuning?
