Page 63 of 136
Re: Formula E
Posted: 11 Aug 2015, 23:20
by domh245
The powertrain would essentially be the inverters (turning the DC provided by the battery into an Alternating Current, usable by the motors) and the motors. I would guess that the gearbox and driveshaft as well.
Re: Formula E
Posted: 12 Aug 2015, 15:52
by Andres125sx
I´d include the battery, in electrics the battery has a massive influence in perfomance. A poor battery will have a voltage drop when discharging at high current, while a good battery will hold a higher voltage. Since final rpm are a function of motor kv (rpm/volt) and battery voltage, the battery is as important as the motor itself
Re: Formula E
Posted: 13 Aug 2015, 11:55
by autogyro
I am disappointed that there is little tech info on the eight homologated power trains that will be used in FE next season.
It is time the series was taken more seriously.
Re: Formula E
Posted: 14 Aug 2015, 10:34
by piast9
For season two the rules regarding the powertrains have been opened and eight new manufacturers have entered Formula E. The new motors, invertors and gearboxes have created unique new sounds. Listen to the difference here.
Re: Formula E
Posted: 22 Aug 2015, 10:40
by J.A.W.
Sounds.. just bloody lovely..
..if you are a dentist who's really into diggin' the drillin'..
Frankly, a cool synthetic sci-fi type sound-track over-dub.. would be very much preferable, IMO..
Re: Formula E
Posted: 22 Aug 2015, 18:39
by Andres125sx
Nextev is my favourite, it is very different to the rest
ABT is the opposite, too high pitched to me
Re: Formula E
Posted: 26 Aug 2015, 13:26
by Jonnycraig
Jacques Villeneuve backs up what Da Costa, Vergne, Piquet & others before him have stated, in the the Formula E cars are incredibly challenging to drive on the limit:
"It’s better every day and it’s very enjoyable. It’s a proper race car which makes it fun to work with the set up and you can see all the evolutions which is good.
It’s like any other race car in some respects, but to go and get that last tenth is very hard. You really have to drive them flat out and well, which is fun. The energy aspect of things is very interesting, it’s mentally taxing and finding a way to go quick without using all the energy is particularly interesting
We are happy with what we have and it’s good now we have had some wet running because if it’s wet on a street course then it will be hell"
Re: Formula E
Posted: 24 Sep 2015, 18:12
by mzso
Please god give us a direct-drive formula.
Re: Formula E
Posted: 24 Sep 2015, 21:27
by autogyro
mzso wrote:
https://www.youtube.com/watch?v=7zBFeAPSpbM
Direct drive does not make full use of the electrical system.
What they need is a 'gearbox' that uses a shift system advanced enough to do justice to electric drive and silent in operation.
Re: Formula E
Posted: 12 Oct 2015, 21:07
by machin
According to the latest Racetech magazine, the set-ups are as follows:
Single Motor, 5 Ratios; Andretti, Aguri, Trulli
Twin Motor, single ratio: Virgin, NextEv TCr
Twin Motor, two ratios ; Renault E.Dams
Single Motor, 3 ratios; Audi Sport Abt
Single Motor, 4 ratios; Mahindra, Venturi, Dragon Racing,
All drive through a single input mechanical differential (as required by the rules). All use the same battery (as required by the rules), and I believe the battery is limited to a maximum power output (dependent on whether it is race or qualifying), but teams gain by having higher power transmission efficiency...
Re: Formula E
Posted: 13 Oct 2015, 00:14
by Andres125sx
machin wrote:All drive through a single input mechanical differential (as required by the rules).
Differential required by the rules?
What´s the point of using twin motors then?
Re: Formula E
Posted: 13 Oct 2015, 09:16
by machin
Apparently in most cases the twin motors share a common output shaft, but are wound differently and supplied with separate power, this allows them to either power one motor or the other, or both simultaneously, to manipulate the shape of the power curve and/or optimise the powertrain efficiency to the driving scenario (steady-state-cornering, coming out of the corner, end of straight etc.)
Re: Formula E
Posted: 13 Oct 2015, 10:22
by Andres125sx
Interesting thanks
But I can´t understand the mandatory use of a mechanical differential in FE
Re: Formula E
Posted: 13 Oct 2015, 13:39
by machin
I think the plan is essentially to "free-up" different areas of the car season-by-season as a way to control costs... I'm assuming that in seasons to come we'll see the differential and battery being "freed-up" at some point... If they'd done it all in one go then the team with the biggest budget would have a massive advantage over the others....
Re: Formula E
Posted: 13 Oct 2015, 22:07
by dero
I for myself would love to see free battery development.
I don't think it would lead to much better performance but to much more drama.
Imagine a few hundred kilograms of burning Lithium :twisted:
I'm pretty sure it won't happen because the Series was in part created to improve the recognition of e-tech to the mass market. Burning batteries that can't really be extinguished properly would not help.
cheers Stefan
