Page 638 of 668
Re: 2014-2020 Formula One 1.6l V6 turbo engine formula
Posted: 26 Mar 2020, 02:39
by djos
AJI wrote:
26 Mar 2020, 02:05
The only absolute reason no PU era car has ever had a hot vee is because that is what is prescribed in the rules.
As Holm pointed out, two LMP1 cars were hot vee, both designs won championships.
Formula 2 engines are hot vee.
It's clearly not impossible...
If a Hot V configuration was such a great concept for the hybrid PU's, dont you think the teams would have lobbied to have the current restriction lifted?
I think their silence means that it was looked at and discarded as not worth the effort.
Posted: 26 Mar 2020, 03:21
by AJI
djos wrote:
26 Mar 2020, 02:39
AJI wrote:
26 Mar 2020, 02:05
Why all the hate for hot vee? I cite 3 manufacturers who use it, and all I get is no one likes it? So much for innovation...
Anyway, teams don't set the specs. Manufacturers are consulted, but they don't get to write the rules. Do you really think the teams wanted a 3 throw 90 degree V6 with no VVT and only 1 injector to try and build the most efficient engine in the world? Andy Cowell isn't silent. He stated years ago that he'd prefer a v4 or an even firing v6 and lower revs, but he's just the guy who heads up the company that makes the most successful F1 PU of all time, he doesn't get to make the rules.
Anyway, what else are we going to talk about while we're locked down watching an F1 season slowly dissapear?
Posted: 26 Mar 2020, 04:17
by djos
AJI wrote:
26 Mar 2020, 03:21
Don't get me wrong, I'd love to see other Engine configs, however, in the Hybrid era I just don't see the hot-v concept making a meaningful improvement over the cold-v we currently have.
Posted: 26 Mar 2020, 08:33
by Holm86
Also both Mercedes and BMW roadcar V8's are now hot vee's as they claim it's more efficient.
I just don't think the manufacturers care to lobby such a thing, as it isn't a major thing after all, when the regulations are the same for everyone.
As AJI says they don't even lobby an even firing engine at least. And I think I'd be easier to make an even firing engine last longer as it doesn't have the same bad harmonics
Posted: 26 Mar 2020, 08:47
by djos
Holm86 wrote:
26 Mar 2020, 08:33
They aren’t hybrids tho are they?
Posted: 26 Mar 2020, 09:16
by saviour stivala
I haven’t read anybody saying it is not possible, what some have been saying is with the present power unit an exhaust configuration in the vee is not practical. If it was and most importantly offers an advantage of sorts that would have been the direction the present designs would have followed. The rules/regulations disallowing such a set-up, contrary to some believe, have been agreed upon by all of the three original manufacturers at the time the rules were settled upon.
Posted: 26 Mar 2020, 10:25
by Holm86
djos wrote:
26 Mar 2020, 08:47
Holm86 wrote:
26 Mar 2020, 08:33
Your point being?
Posted: 26 Mar 2020, 10:33
by Holm86
And a little edit to my previous post, I didn't remeber correctly, the Porsche V4 is a regular cold vee
But looking at the Audi LMP V6 TDI, I don't think it looks that much wider, keep ind mind that the Porche engine is 90° bank angle, like F1, and the Audi is a 120°
I think it should be possible to tuck those airboxes in on the side of the engine
Posted: 26 Mar 2020, 10:37
by saviour stivala
His point is. No MGU-H on the turboshaft.
Posted: 26 Mar 2020, 10:44
by djos
Holm86 wrote:
26 Mar 2020, 10:25
djos wrote:
26 Mar 2020, 08:47
Holm86 wrote:
26 Mar 2020, 08:33
Your point being?
The hybrid parts add a huge amount of complexity and going hot vee is quite simple when you don’t have hybrid components to package.
Your picture of the Audi engine didn’t help your case, by F1 standards it’s a monster and way way too wide! LMP cars don’t have the same aero constraints as open wheelers and have a lot more space to work with.
Posted: 26 Mar 2020, 11:02
by Holm86
djos wrote:
26 Mar 2020, 10:44
Holm86 wrote:
26 Mar 2020, 10:25
djos wrote:
26 Mar 2020, 08:47
Your point being?
Your picture of the Audi engine didn’t help your case, by F1 standards it’s a monster and way way too wide! LMP cars don’t have the same aero contains ad open wheelers abs have a lot more space to work with.
As I said the Audi engine is 120°, which makes it a lot wider than 90°.
In fact I can't even see why the current F1 engine aren't 60°
Posted: 26 Mar 2020, 11:08
by djos
The rules are what the manufacturers asked for when the FIA consulted them.
Posted: 26 Mar 2020, 11:34
by Holm86
djos wrote:
26 Mar 2020, 11:08
They havde listned to some points from the manufactures, but the rest is dictated by FIA.
Only thing I've heard a team had influence on, was that Ferrari complained about the original idea of a straight 4 engine
Posted: 26 Mar 2020, 12:15
by Tommy Cookers
Holm86 wrote:
26 Mar 2020, 11:02
.... I can't even see why the current F1 engine aren't 60°
60 deg is worse than 90 deg in most ways
Posted: 26 Mar 2020, 13:14
by Holm86
Tommy Cookers wrote:
26 Mar 2020, 12:15
Holm86 wrote:
26 Mar 2020, 11:02
Not when it comes to balancing, if you run even firing.
At least I don't get why offset crank pins arent allowed
