Site maintenance next weekend (15/7-16/7)
Everything about this website and its content. Here you will find update announcements or requests for feedback. Questions about layout, functionality, content, and your suggestions are welcome.
Re: Site maintenance next weekend (15/7-16/7)
just had normal access to the site for the first time this week..Are you getting there?
Steven
Owner
wesley123 wrote:indeed, I took a look at the errors with Opera 11.11 here, returns absolutely nothing. Also what i noticed when looking at the source, it is completely blank. When I 'inspect the webpage' it only shows the html <head> and <body> tags, the two tags required for an page, so my quick guess is; I would say the page you load when typing in 'f1technical.net' is somehow referenced twice.
What I would do at the moment, since you seem a bit lost Tomba, I would just place the previous version back for a while. That gives you the time to work on it and fix mistakes. I wouldnt say it bothers that much since you arent really looking to any critical functions right now that are fixed with the new version.
You can then just work on the website and maybe test it in an VM for example.
The problem is really that the homepage or anything related to it has not even changed a bit. All I did is replace the htaccess file on Fridaynight to show the maintenancepage, and then put the original back a few hours later. Seeing the server logs, the problem occurs since then.
marcush. wrote:just had normal access to the site for the first time this week..Are you getting there?
Unfortunately not. You were just lucky one time.
Dragonfly wrote:The Gallery button is not working and throws the same error message as the one I get with "index.html"
Gallery works fine to me. Anybody else has problems with http://www.f1technical.net/gallery/ ?
I have even tried emptying the homepage and just put "hello", but even that gives the blank page. PHP doesn't report any error whatsoever either, it looks to me like apache just kicks out before even starting to process the page.
I've asked hosting company to look at it. Will not be cheap but it needs to be done...
seems to be working now though, I just could click the Home button 3 times in a row and was directed to the home page without any problem.
also typing 'f1technical.net' redirects me correctly to the homepage.
EDIT: so I came on the homepage correctly like 8 times in a row, suddenly i got a blank page again. I am also getting the 404 error with the Gallery
Ava Pug
Ava Pug
Getting 404 error as well in Firefox 7.
rjsa
rjsa
51
Blank home, 404 gallery on IE9.
Blank home, gallery OK on Safari.
Blank home, gallery OK on FF.
All in the same computer W7 x64. MacOSX/Safari the same as Safari/Win.
Dragonfly
Dragonfly
Tomba wrote: The problem is really that the homepage or anything related to it has not even changed a bit. All I did is replace the htaccess file on Fridaynight to show the maintenancepage, and then put the original back a few hours later. Seeing the server logs, the problem occurs since then.
During the maintenance I did not see any message about it. Only the blank page.
Something with the ownership of the .htaccess file or the attributes? Just guessing though.
Spa 2012
Tomba wrote:Gallery works fine to me. Anybody else has problems with http://www.f1technical.net/gallery/ ?
Gallery gives a 404 here...
Turbo says "Dumpster sounds so much more classy. It's the diamond of the cesspools." oh, and "The Dutch fans are drunk. Maybe"
donskar
donskar
Tried to go from this page to Home and got a 404
rjsa
rjsa
51
Home (/) OK now on all my browsers. Gallery keeps 404 in IE9.
phill.l
phill.l
Tomba,
Accessing the site manually (example telnet session below), you can see phpBB is throwing a PHP error for the Gallery before sending any HTML headers... which is why the page isn't being rendered correctly ;) HTH
Phill
Code: Select all
phill@Laptop:~$ telnet f1technical.net 80
Trying 62.182.62.75...
Connected to f1technical.net.
Escape character is '^]'.
GET http://www.f1technical.net/
<b>[phpBB Debug] PHP Notice</b>: in file <b>/opt/www/vs03001/web/www.f1technical.net/ext/plugins/Gallery2Plugin.class.php</b> on line <b>276</b>: <b>Undefined index:  HTTP_HOST</b><br />
Connection closed by foreign host.
Tozza Mazza
Opera still displaying a blank page on the home page.
My mobile browser (Android) just won't load the site.
Forum, and everything else works good though!
TM.
fenix4life
fenix4life
Tomba wrote: Gallery works fine to me. Anybody else has problems with http://www.f1technical.net/gallery/ ?
On IE i can access it but 404 on FF
phill.l wrote:usefull bla bla
Interresting, but quite weird too. I mean, who would it work sometimes then? Sometimes the page loads, but most of the time it does not.
Steven
Owner
In relation to the gallery, does this work:
http://www.f1technical.net/gallery3/ ?
That's the new gallery that will soon replace the old one...
Also, for those of you that have trouble with /gallery/ , please send me the output of http://www.f1technical.net/server.php
Meanwhile looking into index problem as well...
/Gallery3/ is working, however /Gallery/ is not.
Code: Select all
array(31) { ["DOCUMENT_ROOT"]=> string(41) "/opt/www/vs03001/web/www.f1technical.net/" ["GATEWAY_INTERFACE"]=> string(7) "CGI/1.1" ["HTTP_ACCEPT"]=> string(129) "text/html, application/xml;q=0.9, application/xhtml+xml, image/png, image/webp, image/jpeg, image/gif, image/x-xbitmap, */*;q=0.1" ["HTTP_ACCEPT_ENCODING"]=> string(13) "gzip, deflate" ["HTTP_ACCEPT_LANGUAGE"]=> string(14) "en-US,en;q=0.9" ["HTTP_CONNECTION"]=> string(10) "Keep-Alive" ["HTTP_COOKIE"]=> string(687) "f1technical_poll=a%3A5%3A%7Bs%3A7%3A%22voterid%22%3Bs%3A32%3A%22b155367cee0eb59200135568b6da3691%22%3Bs%3A21%3A%2220110522155435.000000%22%3Bs%3A1%3A%222%22%3Bs%3A21%3A%2220110529162814.000000%22%3Bs%3A1%3A%221%22%3Bs%3A21%3A%2220110628124640.000000%22%3Bs%3A1%3A%223%22%3Bs%3A21%3A%2220110710202858.000000%22%3Bi%3A1%3B%7D; __gads=ID=a317f0784e78f7a0:T=1306107947:S=ALNI_MYp8EiSS2FtcwHHgbfEfEyR_Q_mOw; __utmz=162867627.1306107945.1.1.utmccn=(direct)|utmcsr=(direct)|utmcmd=(none); phpbb3_5nomq_u=5671; phpbb3_5nomq_k=dccf711544e1d411; phpbb3_5nomq_sid=54e7737f7d85648a2754f39451111fba; __utmc=162867627; __utmb=162867627; __utma=162867627.1983443674.1306107945.1311094458.1311099440.474" ["HTTP_HOST"]=> string(19) "www.f1technical.net" ["HTTP_REFERER"]=> string(67) "http://www.f1technical.net/forum/viewtopic.php?f=7&t=10353&start=30" ["HTTP_USER_AGENT"]=> string(63) "Opera/9.80 (Windows NT 6.1; U; en) Presto/2.8.131 Version/11.11" ["PATH"]=> string(28) "/bin:/usr/bin:/usr/local/bin" ["PHPRC"]=> string(42) "/opt/www/vs03001/conf/www.f1technical.net/" ["QUERY_STRING"]=> string(0) "" ["REDIRECT_STATUS"]=> string(3) "200" ["REMOTE_ADDR"]=> string(13) "77.248.180.28" ["REMOTE_PORT"]=> string(5) "63977" ["REQUEST_METHOD"]=> string(3) "GET" ["REQUEST_URI"]=> string(11) "/server.php" ["SCRIPT_FILENAME"]=> string(51) "/opt/www/vs03001/web/www.f1technical.net/server.php" ["SCRIPT_NAME"]=> string(11) "/server.php" ["SERVER_ADDR"]=> string(12) "62.182.62.75" ["SERVER_ADMIN"]=> string(25) "webmaster@f1technical.net" ["SERVER_NAME"]=> string(19) "www.f1technical.net" ["SERVER_PORT"]=> string(2) "80" ["SERVER_PROTOCOL"]=> string(8) "HTTP/1.1" ["SERVER_SIGNATURE"]=> string(71) "
Apache/1.3.34 Server at www.f1technical.net Port 80
 " ["SERVER_SOFTWARE"]=> string(13) "Apache/1.3.34" ["PHP_SELF"]=> string(11) "/server.php" ["REQUEST_TIME"]=> int(1311103893) ["argv"]=> array(0) { } ["argc"]=> int(0) }
