Page 1 of 1
F1 Ground Effect Sidepod idea?
Posted: 13 Mar 2012, 21:02
by RichardF1
After doing a bit of reading on ground effect and that area, I was wondering if it would be possible to make 'ground effect sidepods'. Please let me know, I'm not a techno-wizard and would just like to have a clear answer on would it produce more downforce than the coke bottle design. However, being a newbie at this I don't know how to get my 'car' from Microsoft paint into this.
Re: F1 Ground Effect Sidepod idea?
Posted: 13 Mar 2012, 21:10
by hardingfv32
The floor of the side-pod must be flat and a great distance from the ground per the rules.
Brian
Posted: 13 Mar 2012, 21:14
by RichardF1
its not the floor which will change in height. Using STR's double floor undercut idea, there will be a height rise and then a decrease. Like this:
________
Would love to know how to get my car i've drawn in paint over into the thread.
Posted: 13 Mar 2012, 21:15
by RichardF1
Diagram didn't work...
Posted: 13 Mar 2012, 21:37
by RichardF1
http://www.youtube.com/watch?v=HfIYfYBnZeg
Link to the video of my car idea. The sidepod raised up will help airflow under, then increasing the size underneath and then decreasing the exit size would accelerate airflow?
Posted: 13 Mar 2012, 21:47
by speedsense
RichardF1 wrote:After doing a bit of reading on ground effect and that area, I was wondering if it would be possible to make 'ground effect sidepods'. Please let me know, I'm not a techno-wizard and would just like to have a clear answer on would it produce more downforce than the coke bottle design. However, being a newbie at this I don't know how to get my 'car' from Microsoft paint into this.
IMHO,You have to call that "floor effect" not ground effect. Yes at certain points you would create low pressure areas (along with unwanted high pressure points), however it would do nothing to create downforce as it would do nothing under the car's flat floor.
The sculpted side pods create a "shelf" area above the floor to prevent spilling of air under the floor area (prevention of higher pressure turbulent air pockets under the floor) AND to feed air to the diffuser. The shelf area increases DF by this reduction of spillage.
Posted: 13 Mar 2012, 22:04
by RichardF1
It wouldn't as effective as the coke bottle and undercut style since the beginning of time? I think I'll pipe down and stick to my paint skills
Posted: 13 Mar 2012, 22:16
by Himlar
Speedsense, that sounds like a more plausible explanation than it actually making downforce itself.
I discussed this concept with one of my teachers in fluid dynamics at university a while ago, and since the floor and the sidepod can be viewed as parts of the same rigid body, all upwards and downwards forces created by the Venturi effect will equal themselves out.
