Autodesk Falcon
tomislavp4
Re: Autodesk Falcon
astracrazy wrote:its clearly not as good as paid software, but for free and easy to use its a start.
It is a technology-preview and as such it looks pretty promising. I like how it is developed to be focused on exterior automotive design, it gives Cd and Df values without the user telling it to and isn´t crowded with options that aren´t needed for automotive development.
In it´s current form it really isn´t useful though. As I said before it lacks rolling floor and rotating bodies, features that are very important in this area. The model even sits a couple of dm above the floor and cannot be moved closer to it! That alone makes the Df-value meaningless, doesn´t it? You cannot specify boundary-conditions either. Even if these features were incorporated, I´d still be doubtful of the results. It´s just too fast.
N12ck
Re: Autodesk Falcon
I cant see any obvious place where the overall Cd and Df figures are displayed
Budding F1 Engineer
Monster_Energy_F1
Re: Autodesk Falcon
Anyone got a link for the Plugin?
tomislavp4
Re: Autodesk Falcon
N12ck wrote:I cant see any obvious place where the overall Cd and Df figures are displayed
Choose 3D simulation wait untill the flow lines appear and look at the bottom of the window, right beneath the model. It should say Cd:xxx ; Fd:xxx there is also an arrow next to the values, click it for a graph.
RicME85
52
Re: Autodesk Falcon
Monster_Energy_F1 wrote:Anyone got a link for the Plugin?
just google Sketchup STL plugin
N12ck
Re: Autodesk Falcon
I dont really rate it as a CFD solver or any sort of credible analysis, I have used openfoam before, and from experience, I dont think this one is very good, the problems are:
cannot choose mesh size,
cant gain pressure gradients on the surface of the object,
results dont really 'converge' ,
cannot do much with customizing boundary conditions,
no rolling road,
no turning wheels,
overall I would say as a simple tool to see what the velocity looks like or pressure looks like around a wing it is okay, but other than that I dont think its a very good CFD solver for development.
:D
Budding F1 Engineer
Greg Locock
Greg Locock
233
Re: Autodesk Falcon
yes, openfoam is undoubetdly a better tool in the right hands, at least two automotive oems use it
N12ck
Re: Autodesk Falcon
Greg Locock wrote:yes, openfoam is undoubetdly a better tool in the right hands, at least two automotive oems use it
I managed an analysis at home and I can deffinatley say it is a far superior program to this, this I don't think gives reliable data which can be used to develop with, well not accurately :D
Budding F1 Engineer
CottrellGP
CottrellGP
Re: Autodesk Falcon
It wont let me convert stuff i need help lol
Dan Cottrell
Master Of Innovation!
N12ck
Re: Autodesk Falcon
It isnt that great Dan, I would say stick to solidworks :D
Budding F1 Engineer
astracrazy
astracrazy
31
Re: Autodesk Falcon
of course 100% solidworks, openfoam etc are better. This is just better than nothing
If i had solidworks or could use/understand openfoam i'd use it :D
tomislavp4 wrote: The model even sits a couple of dm above the floor and cannot be moved closer to it!.
I think you can adjust the test area size so i'm guessing you can adjust the y min height which i'm guessing (haven't tried) will move the model closer to the floor (or floor closer to the model)
tomislavp4
Re: Autodesk Falcon
astracrazy wrote:I think you can adjust the test area size so i'm guessing you can adjust the y min height which i'm guessing (haven't tried) will move the model closer to the floor (or floor closer to the model)
Must´ve missed that. It does bring the model closer to the floor alright, but you still cannot make the model touch the floor.
N12ck
Re: Autodesk Falcon
astracrazy wrote:of course 100% solidworks, openfoam etc are better. This is just better than nothing
openfoam is relatively easy to use once you have learned it, only problem is you need linux to run it, and a decent computer :D
Budding F1 Engineer
astracrazy
astracrazy
31
Re: Autodesk Falcon
i have tried it before, have to try again. I think half the problem was trying to understand how to use the linux interface
what does the cd and fd stand for on Falcon?
Greg Locock
Greg Locock
233
Re: Autodesk Falcon
mirror image
with a moving floor the streamline at floor level operates at free field speed and is straight, with no boundary condition.
So if you set two bodies as mirror images, separated by twice the ride height, the streamline between them is straight, and has free field velocity (approximately) and no boundary layer. So it is how people used to get around not having moving floors in wind tunnels.
