Formula E
autogyro
autogyro
Re: Formula E
The thread does not need green bashing either.
What is good for one mindset should be the same for another.
Formula E is now an OFFICIAL FIA Formula.
It is to be worldwide.
It needs to be technicaly evaluated.
gato azul
gato azul
70
Re: Formula E
piast9 wrote:
Wideband mindeD wrote:Isn't it feasible to simply swap the electrolyte liquid out of a lead/acid type battery (maybe the gel type) with some sort of push/pull refueling rig? Car comes in and stops, hook up rig, suck out old gel as new gel is sucked in, change tyres and release.
It's not the electrolyte itself that causes batteries to generate electricity but the electrochemical reactions at the electrodes. Changing only the electrolyte won't cause the battery to be charged. The charged lead acid battery that you mentioned has one lead electrode and the lead oxide at the second electrode, both of which turn into lead sulfate as the battery is discharged.
It depends on your definition of what a "battery" is.
Wideband may had a "flow battery" a.k.a "Redux Flow Battery" in mind, where the composition of the electrodes don't change.
These batteries contain two electrolytes which are separated by a membrane, and get stored in separate tanks.
If you change the electrolytes you change the "charge" in the battery, so what he suggested is in theory doable, and these type of batteries are already in use.
Currently the energy density of these type of batteries is still relatively low, compared to an LiPo battery let's say, but some developments try to address this issue and some inroads have been made recently, to bring them closer to LiPo.
It's one of the technologies in question, to address some of the issues of decentralized energy production, storage and transportation.
It's early days, so it's not a "turn key" technology yet, but get's researched for potential use in EV's of the future.
It still has some way to go in terms of energy density to make it viable.
In tests for possible EV applications 200 l electrolyte where replaced in ~6 min, which would be comparable to refueling a petrol or diesel car.
Flow batteries provide several advantages over conventional battery storage technologies:
a) Power/Energy Design Flexibility. Since electrolyte is stored separately from the reaction stacks, the energy storage rating (kWh) is independent of the power rating (kW). This allows for design optimization for power and energy separately, specific to each application. Therefore, flow batteries have the advantage of scalability. To increase peak power output additional battery cells need to be added. But to increase the amount of energy that can be stored, and therefore to increase the time they will operate on a full charge, can be expanded almost indefinitely by building biffer tanks and filling them with electrolyte. The result is that these batteries can be used in a wide range of roles; from small scale units to power-station scales of hundreds of MWhs.
b) Layout Flexibility. The tanks can be easily arranged to fit the available space and shape of the facility. In one demonstration, the tanks were made of rubber that conformed to the shape of basement walls in an office complex.
c) Low Standby Losses. Depending upon the application, it is possible to drain the stacks and store the charged electrolyte for long periods of time without self-discharge or pump auxiliary loads.
d) Simple Cell Management. Conventional batteries must be periodically charged at high voltages to equalize all cells to the same state of charge. This can produce undesirable levels of explosive hydrogen gas (a safety issue) and reduces the available water in the battery (a life issue). In flow batteries, however, all cells share the same electrolyte at the same state of charge, so equalization is unnecessary.
autogyro
autogyro
Re: Formula E
I am glad I am on this technical forum and not some old boys network thread for the dim.
That Duck guy over on the Autosport E formula thread, is now asking someone to explain to him where electricity comes from.
You realy couldnt make it up could you.
autogyro
autogyro
Re: Formula E
Tommy Cookers wrote:@ gato azul
zero carbon claim for bioethanol is surely based on the CO2 emissions being absorbed by the next generation of (cane) bioethanol
US sourced bE is from corn, requiring fertiliser and more work, giving small carbon benefit (why IRL changed from corn to cane bE)
cane bE can be better, but can be bad carbonwise as all bE causes 50 year carbon release if ploughing virgin land
not @ gato azul
so cane bE can be ok, corn or wheat bE is simply fraud (by governments making themselves look good) .... fraud won't save the world (biodiesel can be ok,too, but often bad for carbon release and for orang-utans etc)
similarly electric cars are (government) fraud (until we have majority low-carbon electricity, which IMO can't happen ?)
this thread has shown me that for PR purposes racing needs to kiss up to greeness (however fraudulent)
but that shouldn't stop F E being an efficiency formula, not another inefficiency formula ?
All alcohol burnt from plant sugar is CO2 neutral.
Fossil fuel burning producing CO2 is 100 percent extra CO2 released into the atmosphere.
So please can we gat away from these puerile attempts to discredit green issues for the sake of fossil fuel greed.
It realy does not do anything other than make the posters look silly and completely diverts the thread subject.
Which is of course the intent.
Some of us have had to put up with this campaign of half truths for decades and everybody should now realise the huge burden of cost this has placed on all of us.
Formula E shows that the FIA are now dedicated to reversing this criminal waste.
olefud
olefud
79
Re: Formula E
Cam wrote:A simpler and far better way of promoting Formula E as a 'green' form of racing would be to Carbon Offset it and actively show what teams are doing. If they open up the inner workings and can publicly show that the cars and teams are both using as much renewable and recycled material where possible and offsetting what's left over. Image
Supporting renewables is asking me to support a system that is contrary to my fundamental belief system i.e. I don’t believe that things can be renewed, at least not with regard to energy. I worship at the altar of entropy. Basically, I believe that the universe popped into being at a very high energy state and has been running down ever since. We can’t go back and renew energy; at best we can extract work as it passes from one state to a lower state on the way to cold and dark.
Fundamental beliefs should not be subject to political decree or marketing hype. Racing IMO should be about excellence for excellence sake and should steer clear of the bare-butt emperor with his cloak of renewability. There’s enough politics in racing already without dragging renewability in too.
That said, I certainly respect anyone’s right to believe differently provide the respect is reciprocal.
so I'm not actually against promoting Formula E in terms of renewables, but I personally couldn't support it. Why not cast a wider net?
Pierce89
Re: Formula E
autogyro wrote:What makes me laugh is the lengths the 'anti greens' will go in their attempts to discredit electric vehicles and electric racing.
On that weird Autosport forum they even have some duck guy telling everyone his Brother or someone commutes 600 miles every day, I will say it again 600 miles every day.
Someone called him a bullsh--ter and he complained over the label.
If I wasnt banned I would have posted just to offer the daft guy's brother a proper job.
I think the label fits perfectly.
But then it was for telling the truth that I got banned for in the first place.
Sorry guys, electric racing is here to stay.
I love the idea of electric racing. I just hate that the FIA cocks up everything.
autogyro
autogyro
Re: Formula E
Formula E is electric car racing, not a marketing idea for renewables. [...]
This is neither a religiouse thread or a thread for arguments against green issues. [...]
Reason: Strip the heated parts ;)
Forza
238
Re: Formula E
[youtube]http://www.youtube.com/watch?v=nDZ4VSFC6z0[/youtube]
Technical Data EF01 (prototype)
Top speed: 250 km/h
Acceleration: 0 à 100 km/h in 3 seconds
Race autonomy: 20 minutes
Gearbox: 2 speeds
Time in qualification lap: close to that a Formula 3
Time of recharge: between one and one and a half hours
Source
autogyro
autogyro
Re: Formula E
skgoa
skgoa
Re: Formula E
olefud wrote: Supporting renewables is asking me to support a system that is contrary to my fundamental belief system i.e. I don’t believe that things can be renewed, at least not with regard to energy. I worship at the altar of entropy. Basically, I believe that the universe popped into being at a very high energy state and has been running down ever since. We can’t go back and renew energy; at best we can extract work as it passes from one state to a lower state on the way to cold and dark.
:wtf:
#-o
:cry:
olefud
olefud
79
Re: Formula E
:wtf:
#-o
:cry:
You missed an important part of Cam’s quote. I’m interested in and can support new technologies. When terms such as “renewable”, “offsetting” and “conflict minerals” are used we’re into marketing hype at best and politics at worst.
I’m sort of hoping we can keep it in the technical domain.
jdlive
jdlive
-3
Re: Formula E
Forza wrote:[youtube]http://www.youtube.com/watch?v=nDZ4VSFC6z0[/youtube]
Top speed: 250 km/h
Gearbox: 2 speeds
Source
An F3 car which makes even less noise than an F3. Not going to be the greatest spectator attracting series :D
"There is a credit card with the Ferrari logo, issued by Santander, which gives the scuderia a % of purchases made with the card...
I would guess that such a serious amount of money would allow them to ignore the constant complains of a car that was nowhere near as bad as their #1 driver tried to sell throughout the season.
Heck, a car on which Massa finishes in the podium or has to lift so that his teammate finishes ahead (As we saw often in the final races of the year) is, by no means, a "bad" car."
WhiteBlue
92
Re: Formula E
jdlive wrote:An F3 car which makes even less noise than an F3. Not going to be the greatest spectator attracting series :D
I don't think that noise is as much an issue as with F1 when it comes to electric racing. You certainly do not attach as high a value on it as you do in F1. Personally I would not mind a formula without much noise if it focusses on performance and the promotion of valuable technology. Horses for courses would be a good motto.
jdlive
jdlive
-3
Re: Formula E
It's interesting for all of those involved and everyone interested in the technologies used. But, an F3 race is already pretty much boring as --- due their lack of speed (when viewed from alongside the track) and due to their non-existant sound. This will be even worse for spectators. No one is going to show up. At the latest F3 race at Spa there were hardly any spectators and it was free entrance.
BUT, I assume this is only just the beginning, and that both the speed and the sound will pick up eventually one way or another.
autogyro
autogyro
Re: Formula E
Formula E races will be CITY center races.
Rio is already confirmed and Monaco has confirmed its interest in running races.
There will be lots of spectators all around the world.
F3 at Spa is no comparison at at all.
FE is the start of a NEW racing technology with almost endless development potential.
There is a need now for a big marketing campaign.
If it is a tenth the size of the current marketing budget for F1, FE will easily succeed.
The problem is the reluctance of the main and specialised media to even recognise that the formula exists let alone give it the coverage it deserves.
Other areas of IC interest are also actively blocking coverage.
Not sensible when governments continue to state that road vehicles will be well over 50 percent electric by 2050.
The above is a statement of fact, not a 'green' issue open for argument.
http://vimeo.com/50129899
