AlpineF1's 3D F1 car
AlpineF1
AlpineF1
Re: AlpineF1's 3D F1 car
Thanks just got the exporter, any opinions on the car :)
And so you touch this limit, something happens and you suddenly can go a little bit further. With your mind power, your determination, your instinct, and the experience as well, you can fly very high.
Ayrton Senna
My blog
Twitter
Facebook
RicME85
52
its coming along.
have you used a car from the google warehouse as a base? it just looks a little familiar.
AlpineF1
AlpineF1
Yes i kinda built around the tub as i tried to make one but it was impossible i dont know how you guys do it :lol:
Ayrton Senna
My blog
Twitter
Facebook
RicME85
52
do you use msn? if so send me a pm with your address.
AlpineF1
AlpineF1
No, cant you PM me on here i could PM you my email address?
Ayrton Senna
My blog
Twitter
Facebook
RicME85
52
i was going to show you a few bits and pieces if you did use msn.
fire me a pm with your email address and I'll send some stuff your way too look at
AlpineF1
AlpineF1
Sure, thanks mate :D
Ayrton Senna
My blog
Twitter
Facebook
AlpineF1
AlpineF1
Ok i have just entered KVRC i know i said i wouldnt for a while but it means that i can get started on properly developing the tub and sidepods. And also get some experience before it all starts so nobody has an advantage over me, hence me seeing change and change corresponding to points :)
Ayrton Senna
My blog
Twitter
Facebook
AlpineF1
AlpineF1
Hi people
There may not be any updates for a bit as most of the work on the car is either inside it or hardly noticable at all. I would expect no normal updates for a few days the car nearly meets the regs i think just need to add exhaust, engine,gearbox and check my sidepods fit in the boxes :D
Ayrton Senna
My blog
Twitter
Facebook
AlpineF1
AlpineF1
Hello everybody
My car is ready just needs exhausts then its ready to rumble :D
Ayrton Senna
My blog
Twitter
Facebook
AlpineF1
AlpineF1
My car i think at least matches all regulations this is a photo of the supplied guidelines for chassis building mine fits in pretty well, judge for yourselves :D
Ayrton Senna
My blog
Twitter
Facebook
N12ck
AlpineF1 wrote:Image
what is the wheelbase on your car, ours is 3400mm, if yours isn't 3400mm it wont match up, also for 2013 it must fit in the boxes, for 2012 however, we are just gauging CPU time and testing all the systems :)
Budding F1 Engineer
astracrazy
astracrazy
31
nick, why does it have to be the same wheel base? Does the car have to fit in with F1 regs, or with your boxes? Because my wheel base is slightly longer than yours
N12ck
astracrazy wrote:nick, why does it have to be the same wheel base? Does the car have to fit in with F1 regs, or with your boxes? Because my wheel base is slightly longer than yours
It does say in the rules it must fit the boxes or it's illegal, as we can't make regulation checkers for each individual wheelbase each team uses, this is the only accurate way of checking if a car is legal within sketchup, so the wheelbase for 2013 must be 3400mm, aside from that the virtual stopwatch is configured to 3400mm wheelbase to isolate the aero effects on laptime.
Budding F1 Engineer
