what do you want to edit? The physics are all just files you can adjust in notepad, and the models are done via .GMT files, which are either loose or in a .MAS file. this is then linked to a .cas file(iic) whch tells what model is what. You apply textures by mapping them on the car and either use .tga, .bmp or .dds files.
