did anyone try to build H pattern to sequential kit?
Posted: 13 Jan 2013, 06:44
I know it is available to buy 1 but it is so expensive, did anyone try to build 1 by yourself?
Not many I would have thought.scarbs wrote:A french company called Selexy tried to market a sequential gear shift for "H" gate boxes. I don't know if any ever got sold.
Sequential shifting only works well if it is computor controlled and the shifting components are some form of pre-loaded quick shift mechanism, which the makers call seamless (wrongly).gixxer_drew wrote:If you are after shift times you can get 95% of the way there by designing a nice H pattern shifter. If you are talking about something fitted into an OEM style casing designed for syncho shifts you shorten the fore/aft throw a lot and the side to side throw a little. Get a nice sensor setup for the shift cut, move the whole assembly close to the steering wheel and it will work pretty darn good and close to a sequential in terms of the shift time.
William did a test with a CVT some time in the 90's I think but it was quickly banned, I'm sure partly based on itautogyro wrote:
snip
Of course if you use a planetary gearset you can then change much more efficiently and far faster.
You can also use as many gears as you like, which is why the FIA limited the number of ratios to 7.
That was after I spoke to Garry Anderson at Jordan about the potential for an 8, 15 or 25 speed bevel epicyclic geartrain.
Garry asked me how many gears maximum would a driver be capable of using with his stop gap manual sequential idea.
Jordan didnt have a budget for the new auto/semi auto systems that I discussed with Ferrari at the time.
The Jordan car was built with 7 and the FIA latched onto that to establish the maximum ratios allowed.
Not sure why they mandated sequential, perhaps you could ask them.
I think it had something to do with coasting under braking when shifting from 7 to 3/2 but I may be wrong.
David Coulthart tested the car.William did a test with a CVT some time in the 90's I think but it was quickly banned, I'm sure partly based on it
wouldn't sound right just going around at a constant ~16000rpm
