Page 1 of 2
Exhaust CFD Comparison
Posted: 19 Jan 2013, 23:49
by amouzouris
I carried out a CFD (Computational Fluid Dynamics) test to compare the two exhaust solutions that were used in the 2012 season, the McLaren style exhaust (1st Picture) and the Red Bull-Sauber Style exhaust (2nd Picture). There has been a lot of discussion about which one of the two solutions is the best and which solution teams will follow in 2013.
I removed the drive shafts, suspension wishbones and pullrod, to keep the test as simple as possible. I did not include a rear wing to reduce the time needed for the test to be carried out. In general, I tried to keep things as simple as possible.
I used a road speed of 55 m/s (200 km/h, 124 mph) and the exhaust speed out of the pipe is at 350 m/s and 850 degrees Celsius.
These are my results:
I obviously didn’t manage to get the exhaust plume to bend down to the diffuser in my first iteration of the McLaren style sidepods (1st Picture), but it is definitely possible. This indicates that using this solution it is harder to get the exhaust plume flowing exactly where you want it as opposed to the Red Bull – Sauber style sidepods which I got almost right on the first try (2nd Picture).
It is believed that using the Red Bull ramp it is easier to get the plume where you want as it is continuously following bodywork to reach the diffuser. My results support this belief, and show a more consistent and predictable flow, which will in turn produce more consistent downforce.
I believe that more teams will follow the trend set by Red Bull and Sauber in 2012 as it is, as I believe, the better solution.
Here are some more shots of the CFD test:
http://technicalf1explained.blogspot.co ... g-cfd.html
PS: Where the left wheel is not visible it is just hidden, it was included in the test.
Re: Exhaust CFD Comparison
Posted: 20 Jan 2013, 00:24
by heho07
Is your Mclaren exhaust plume horizontal that exhaust gas can not bent down to diffuser?
Posted: 20 Jan 2013, 00:49
by wesley123
heho07 wrote:Is your Mclaren exhaust plume horizontal that exhaust gas can not bent down to diffuser?
On the McLaren it is horizontal too, the rules dont allow the exhaust to be bent down, they have to point at least 10 degrees upwards. And this is where the coanda effect kicks in, to help the flow get attached.
Posted: 20 Jan 2013, 01:32
by mikhak
Nice pictures. Could you explain how you visualised the exhaust plume?
Posted: 20 Jan 2013, 01:54
by heho07
wesley123 wrote:heho07 wrote:Is your Mclaren exhaust plume horizontal that exhaust gas can not bent down to diffuser?
Oh my bad.i want to say exhaust duct!
is amouzouris Mclaren exhaust duct flat and horizontal?
Posted: 20 Jan 2013, 10:06
by amouzouris
heho07 wrote:wesley123 wrote:heho07 wrote:Is your Mclaren exhaust plume horizontal that exhaust gas can not bent down to diffuser?
the ducts are actually facing 10 degrees above the horizontal as require in the regulations
Posted: 20 Jan 2013, 10:42
by amouzouris
mikhak wrote:Nice pictures. Could you explain how you visualised the exhaust plume?
I didn't fully understand what you mean! But i used Solidworks to model the car and used Solidworks FlowSimulation to solve it! The lines are produced after the car is solved. I hope this answers your question!
Posted: 20 Jan 2013, 14:35
by timbo
Don't think McLaren's model correlate to reality much. Weren't that apparent that the flow from the exhaust is touching the floor ahead of the tyres? I seem to vaguely remember the pictures of burnt floor.
Maybe you can tweak your settings to match that, and then apply results to RedBull also?
Posted: 20 Jan 2013, 20:17
by amouzouris
timbo wrote:Don't think McLaren's model correlate to reality much. Weren't that apparent that the flow from the exhaust is touching the floor ahead of the tyres? I seem to vaguely remember the pictures of burnt floor.
Yes you are right! my model is probably not producing enough downwash and the coanda ramp is a bit too short! with a bit of tweaking i could get the results right! in addition, the Mclaren style sidepod works better at medium speeds than at higher speeds, i tested it at 200 kph. maybe reducing the speed will bend the exhaust down a bit more!
Posted: 20 Jan 2013, 22:11
by timbo
amouzouris wrote:Yes you are right! my model is probably not producing enough downwash and the coanda ramp is a bit too short! with a bit of tweaking i could get the results right! in addition, the Mclaren style sidepod works better at medium speeds than at higher speeds, i tested it at 200 kph. maybe reducing the speed will bend the exhaust down a bit more!
Hey, that could be very interesting thing to look at!
I always thought that Sauber/RBR style exhaust gave much better flow around the diffuser, but maybe McLaren way can actually help to control DF at top speed.
Posted: 26 Jan 2013, 02:21
by PlatinumZealot
Your model needs some fine tuning. There are some geometrical and physical details you have overlooked.
This car is based on the "chassis" from a user called "machin" It was heavily bastardised...sidepods wings suspension etc.
Here is my model at 216km/hr:
Posted: 29 Jan 2013, 18:47
by amouzouris
I carried out this CFD test to help me understand better the effect of vortex generators on the trajectory of the exhaust plume.
This first test was carried out without any VGs:
The second test was carried out with one VG. You can see how the exhaust plume was deflected towards the tire.
The third test was carried out with 2 VGs. The deflection this time was minor, but was made apparent because it was pushed towards the tire and the 'dirty' air behind it which messes up the flow of the exhaust plume.
http://technicalf1explained.blogspot.co ... haust.html
Posted: 29 Jan 2013, 22:07
by slimjim8201
Posted: 30 Jan 2013, 01:56
by heho07
Great job amouzouris.
Scarb said before that VGs are there to push exhaust plume further down but i can not see vortexes that goes above exhaust plume in your CFD simulation.
Posted: 30 Jan 2013, 02:08
by PlatinumZealot
slimjim8201 wrote:Interesting topic. I've dabbled in this area as well and agree with n smikle that a more detailed CAD model is necessary. As many on this forum have discovered, obtaining a true to life F1 CAD model is nearly impossible and creating one from scratch can be extremely taxing. Sometimes we get lucky, though. These are results from a Dallara IR07 Indycar I ran a while back.
Yeah, detail in both the geometry, and your parameters and your mesh settings and your calculation settings.
