2013 Testing - Jerez 5-8 Feb
ajdavison2
ajdavison2
30
Re: 2013 Testing - Jerez 5-8 Feb
n smikle wrote:
ajdavison2 wrote:
The new Red Bull looks a step forward from the car that ended the 2012 season fighting for wins with McLaren. Aerodynamically it is efficient, as Adrian Newey’s cars always are. It’s not done any eye catching times yet; this is classic Red Bull, they don’t show their hand. As has been the trend in recent years, the Red Bull is the second slowest car on the straights: Vettel was clocked at 291km/h in the speed trap, compared to 305km/h for Force India and Lotus.
The parts I have highlighted each contradict each other do they not? Claiming that the Red Bull is aerodynamically efficient, but is also nearly the slowest in a straight line? Also I was under the impression that Newey's cars have never really been very efficient in the sense that he has always gone for the high DF/low top speed approach? Assuming that I'm understanding 'aerodynamically efficient' to mean high DF/low drag?
RedBull is damn aero-efficient. What you see is gearing... the bulls don't need top speed because they can accelerate like a bat out of hell.
Hasn't it been quite well documented that the RBR cars since about the rb6 have had inherently draggy chassis?
beelsebob
beelsebob
85
n smikle wrote:A little gift
Wow, looking at that, I can suddenly see why Merc think they have a top 3 car this year.
Where's Ferrari though?
GrizzleBoy
GrizzleBoy
What does it mean O_O
Saribro
Saribro
Looks like laptime progressions across stints.
CHT
CHT
-6
beelsebob wrote:
CHT wrote:I thought what they did was changing the gear ratio and aero set up to maximize their straight line speed within the drs zone so that he can overtake the slower cars. Which part is illegal?
The DDRS part of it.
why was ddrs even illegal when other teams are also running their own version?
Red Schneider
Red Schneider
At a glance the chart looks decent for Merc to my eye. I was initially put off by the very high slopes of the Merc lines in some areas, and their stints to the right didn't look very competitive, but in the bottom right they look almost like a match for McLaren, for whatever it's worth.
There are only three Red Bull lines but they look tops to me.
You want a low line with as little slope as possible.
(Those are minimum seven lap stints - laptime in seconds on the vertical axis, laps on the horizontal)
Forza
238
The graph only shows 7 laps+ (vueltas) long stints and as timing from f1tests.info suggests Ferrari only did max 6 timed laps on day 4. However they've longer runs on day 2-graph and day 3-graph.
Hail22
144
Gilles Villeneuve
Javert
McLaren Pit stop problem at 06:10 :mrgreen:
Reason: removed quoted video
GrizzleBoy
GrizzleBoy
And when he comes in for the next stop, he stops too far and can't see the light system properly.
When Sergio pulls out to be wheeled back in, the mechanics throw a black towel over the exhausts......with the initials "LH" on them.
It would be interesting to know whether they used these towels last year. If they are a new thing, we can imagine that McLaren would have fully expected Lewis to be with them right now.
beelsebob
beelsebob
85
It wasn't – the assertion was that it will be illegal in 2013.
Mandrake
Mandrake
Bob I still don't get why you insist their DDRS helped them in AbuDhabi......
They've had it bolted on before and after the change. The effect hasn't changed. Everything else has, wing angles, gear ratios, that's been it. DDRS helped them before and after. Key change was setting the car up for higher topspeed sacrificing cornering speed. They could still do it this year. Also, topspeed is not everything (when not in a dogfight), remember when RedBull won in Monza with one of the slowest cars....They want to accelerate quicker, others want to have a higher top speed.
That last bit was to see in Austin, LH could not pass vettel on the straight as long as nobody cocked up in front of vettel.
dren
226
The Merc is chewing its rear tires again, likely due to a lack of rear downforce.
Honda!
Alexgtt
Alexgtt
GrizzleBoy wrote:And when he comes in for the next stop, he stops too far and can't see the light system properly.
They used them right through last year.
Juzh
161
Mandrake wrote:Bob I still don't get why you insist their DDRS helped them in AbuDhabi......
Very good explanation. +1
