Subaru Impreza Pikes Peak
flynfrog
Re: Subaru Impreza Pikes Peak
Moving your wing forward will help. adding rake.
flynfrog
or put a big wing on the front too
MadMatt
MadMatt
125
The front wing is out of question because I don't want to block the entry to the intercooler (as I don't know the engine needs, for a safety reason I won't block it). Moving the rear wing forward is a good idea however, and I have considered moving the upper tier forward a bit, I still have to simulate this case!
I have indeed investigated rake angle, I will post results of this next week! :wink:
Results of the version I posted above will be posted in few minutes :)
MadMatt
MadMatt
125
So finally the values of my "real" Pikes Peak v1 from where I will try to improve the aero balance without reducing the downforce and efficiency:
- Downforce: 6902[N]
- Drag: 2189[N]
- Lift-to-drag ratio: -3.152:1
- Lift coefficient: -2.116
- Drag coefficient: 0.671
- Aero balance: 18.9% at the front
I will also use it to do my yaw, altitude and dynamic investigations!
MadMatt
MadMatt
125
Results of Pikes Peak v2 are up, and below is a comparison with Pikes Peak v1 on a downforce point of view:
>> HERE! <<
Next time I will present 2 other iterations on trying to balance the car a bit more, and then I will present some graphs! I am also working on yaw at the moment and it it taking me lot of time.
Thanks for the interest! :)
MadMatt
MadMatt
125
I will also conduct a pitch sensitivity of the car since the 1° rake angle applied changed the downforce and balance a lot. I will simulate from -1.5° to 1.5° with 0.5° increments. I won't try to reduce pitch sensitivity on the car because of lack of time, but what is the methodology on this without reducing the downforce of course (assuming there is a way)? :)
I know that reducing overhang for downforce generating parts is a way to reduce it, but are they others?
MadMatt
MadMatt
125
Well, no real interest anymore but I will keep you guys posted. I have, in my (little) free-time, been working on a new model. I will do all CAD optimization and CFD work after I finish my Subaru project, but I will explore more exotic ways of producing downforce, using this car:
Fabia?
MadMatt
MadMatt
125
Yes, Fabia WRC :)
roblomas52
roblomas52
Have you thought about full length ground effect tunnels in the sides?
MadMatt
MadMatt
125
roblomas52 wrote:Have you thought about full length ground effect tunnels in the sides?
I don't want to touch the chassis, therefore yes I could seal the sides but the car is already sitting quite low. If that is what you mean. A good thing would be to build a tubular chassis and incorporate in the design of the tubes some channels for the tunnels! :)
MadMatt
MadMatt
125
Following Blanchimont's idea with Optimum Lap and using his track, I have conducted a small dynamic analysis of the different models that I have made:
>> HERE! <<
Check it out :)
MadMatt
MadMatt
125
I have released some results of a pitch study that I have done:
More details as usual: >> HERE! <<
MadMatt
MadMatt
125
As I am now looking for a job, I have some time for my personal projects, one of which is this Skoda Fabia Pikes Peak using different methods than I used for the Subaru!
I have pusted on the blog the last chapter of the project (about time I know) regarding yaw. :D
P.S.: Could a mod rename the title of the thread "Pikes Peak unlimited CFD cars" please.
exist
exist
Hello,im interested in CFD you made for a pikes peak subaru. How is possible to mail you ?
