2013 Belgian GP - Spa
Post Reply
komninosm
Re: 2013 Belgian GP - Spa
Juzh wrote:
Shrieker wrote:On a second thought, Merc's Eau Rogue exit speed was slow because the plank was scraping the track more than others, result of extra downforce being carried. Now that makes sense. Especially coupled with Hamilton's sector 2 performance in q3.
Mercs had noweher near as much downforce as red bull did, prooven by 2nd sector times troughout the race. More wing doesn't stricly mean more downforce.
Sometimes less is more?
It isn't all about the rear wing. Say mercedes went for a wet setup. That could have meant the suspension had both a higher and softer setup. That's good for keeping stability and driveability in the wet. However, in the dry it'll mean the diffuser is much less efficient. So that way your car can have less downforce despite a bigger rear wing.
Vasconia
turbof1 wrote:It isn't all about the rear wing. Say mercedes went for a wet setup. That could have meant the suspension had both a higher and softer setup. That's good for keeping stability and driveability in the wet. However, in the dry it'll mean the diffuser is much less efficient. So that way your car can have less downforce despite a bigger rear wing.
True, and in consequence the unexpeted (and boring) dry conditions ruined the team´s options for the victory. I would like to see a wet race because a 1-2 for the german team is more than a real chance.
Juzh
161
Vasconia wrote:I would like to see a wet race because a 1-2 for the german team is more than a real chance.
Based on what?
Powershift
-2
I dont think they went for a wet setup, I think they just misjudged the amount of rear wing to run and ran too much. It just so happened to help them in the damp Qualifying, but hurt them in the dry race.
Winning is the most important. Everything is consequence of that. Being second is to be the first of the ones who lose.-Ayrton Senna
Except they weren't fastest anywhere. You'd expect that normally that amount of rear wing helps you in sector 2 and on top of eau rouge, but Mercedes was nowhere good.
Powershift
-2
A valid point, it was a very difficult weekend to make any solid conclusions from the outside with the wild weather fluctuations.
Post Reply
