Page 1 of 1
graphite powder on wheels - f1 in schools
Posted: 15 Dec 2005, 00:46
by paulwils7
Would coating the wheels in graphite powder be a good idea on our f1 cars so as to reduce friction between the wheels and the track?
Thanks
Brisk in Pink
Posted: 15 Dec 2005, 02:52
by Guest
But... why? You'd want *maximum* friction between the tires (not wheels) and the track.
Posted: 15 Dec 2005, 03:55
by manchild
What is the surface/track made of?
Posted: 15 Dec 2005, 04:39
by paulwils7
track is basically a melamine board
Posted: 15 Dec 2005, 17:45
by manchild
Well, if you want them to start rotating at once you must search for friction but perhaps a bit sliding instantly after the cartridge is activated could be better than forcing cartridge to start rotating wheels in order to move the vehicle forward.
Posted: 17 Dec 2005, 03:34
by DaveKillens
Is there any specific rule as to the tire material? Basically, the softer, or spongier the material, the more rolling resistance. In land speed record cars, where traction isn't critical, but rolling resistance is important, they have them rock hard, some even made out of metal. I suggest a tire as hard as possible, maybe aluminum, or steel.
Also, do the rules require the wheels to roll flat on the surface? I would add radical camber, so as to have the wheel running just on the rim.
Posted: 17 Dec 2005, 03:40
by paulwils7
wheels need to run flat on the surface and are not allowed to have any camber. Most are made from plastic or metal. We have seen wheels that have a graphite permacoat on the web for pinewood derby cars.
Any thoughts and ideas on wheel design would be appeciated. Rules are min wheel width 15mm. Min wheel diameter = 26mm
Brisk in pink racing
Re: graphite powder on wheels - f1 in schools
Posted: 12 Mar 2010, 07:03
by flameracing
omg brisk in pink racing
Re:
Posted: 12 Mar 2010, 17:59
by autogyro
paulwils7 wrote:wheels need to run flat on the surface and are not allowed to have any camber. Most are made from plastic or metal. We have seen wheels that have a graphite permacoat on the web for pinewood derby cars.
So start by cutting holes all over the contact area.
