Ferrari F14T
DAMNINice
37
Re: Ferrari F14T
Crabbia wrote:
stefan_ wrote:Winter Testing 2014 - Session 3, Day 2 - Bahrain (28.02.2014)
http://i.imgur.com/IvN1qSP.jpg
Not to start another rake debate but if you look at this the bottom of the diffuser looks to be inline with the wheel rim.
Also there are mclarenesque thin finned louvers attached to the crash structure just above the diffuser, easily visible as they look to be metallic.
I did a comparison picture of W05 and RB10..
I´ve added the Ferrari for you guys:
REal men play with twins!
f300v10
f300v10
183
Re: Ferrari F14T
New rear brake duct winglest today. They were straight before, these curve upwards and then flatten back out:
mclaren_mircea
mclaren_mircea
Re: Ferrari F14T
rapha-78 wrote:Why aren't they using the monkey seat they brought at bahrein 1 ? With the lack of downforce of these cars it could help ?
It may not bring the expected performance.
el-Magico
el-Magico
-10
Location: The number above shows the current temperature
Re: Ferrari F14T
https://pbs.twimg.com/media/BhkQjRaCEAArh0_.jpg:large
Not sure why this would get a +1, the Ferrari is clearly smaller in the picture and therefor this comparison is not useful..
Quote of the year: "almost as sickening as the Velcro fluff under Lewis' cap..."
emmepi27
emmepi27
141
Re: Ferrari F14T
f300v10 wrote:New rear brake duct winglest today. They were straight before, these curve upwards and then flatten back out:
http://www.formula1.com/wi/enlarge/sutt ... 8fe182.jpg
Good spot! I made a comparision between new/old spec
Re: Ferrari F14T
Slightly different double gurney tab arrangement too.
f300v10
f300v10
183
Re: Ferrari F14T
This one has be a bit puzzled. They ran a different rear wing flap with a straight trailing edge and no Gurney flap:
beelsebob
beelsebob
85
Re: Ferrari F14T
f300v10 wrote:This one has be a bit puzzled. They ran a different rear wing flap with a straight trailing edge and no Gurney flap:
http://www.formula1.com/wi/enlarge/sutt ... 8fe266.jpg
Why is that puzzling?
C Plinius Secundus
C Plinius Secundus
Re: Ferrari F14T
Hi, am I wrong or this exhaust/rear wing flow looks pretty decent?
Does the exhaust flow turn upwards quite sharply right over the rear crash structure? :?:
I'm sure the aerodynamics experts here will know best!!
PS: Did Ferrari return to the "slim" exhaust-engine cover from the bulged one used by Raikonen yesterday?, Or is it a new "intermediate" one?
f300v10
f300v10
183
Re: Ferrari F14T
Running with no Gurney flap. And notice how the trailing edge is lower than the endplates. They were probably just testing something, I don't expect to see that configuration race trim.
Ganxxta
Ganxxta
Re: Ferrari F14T
Might have been a low drag variant, no?
emmepi27
emmepi27
141
Re: Ferrari F14T
A little comparision to show some news in the central section (up last spec - ph Sutton):
aleks_ader
88
Re: Ferrari F14T
Ganxxta wrote:
f300v10 wrote:
beelsebob wrote:[Running with no Gurney flap. And notice how the trailing edge is lower than the endplates. They were probably just testing something, I don't expect to see that configuration race trim.
I belive they just remove gurney rest of the wing is of course the same. :?: So anyway i are with beelsebob that is just some sort unusual testing.
It is strange beacuse the gurney help wing to prevend detacment of the flow when is car during yaw and pich.
beelsebob
beelsebob
85
Re: Ferrari F14T
f300v10 wrote:
beelsebob wrote:Why is that puzzling?
What's wrong with running no gurney tab?
Remember, the entire point of a gurney tab is that it's a quick hack that can be added to the back of a wing to increase it's downforce in an emergency. They are explicitly things that are meant to be easily removable. The norm is to run without them.
Cuky
65
Re: Ferrari F14T
aleks_ader wrote:I belive they just remove gurney rest of the wing is of course the same. :?: So anyway i are with beelsebob that is just some sort unusual testing.
Whole flap is different. If they had just removed the gurney there still would be two V cuts on the flap
