I wonder what sort of sideways G forces the NSX could generate.
Running components on a track will almost certainly give Honda an insight as to how reliable they will be, and using them on a car that can run endlessly must also be a bonus.
I think they still smart from the vibrations problem they missed until it was fitted into the car.
That'd require them to shoehorn in the entire PU drivetrain, with a Red Bull rear into an NSX with F1 wheels and tires, not just "slap" the MGUH onto an NSX turbine(s).
I think they wil clutch at ant straws in reach. Even if it does no good it probably makes them feel better
They can use a non-homologated engine if they like, and slap a RedBull drive train on there...
Will surely not even be close. I was calculating a bit with some co workers the other day. Rubber to asphalt
2G would still give better info than the maximum 1G on a dynoBandit1216 wrote: ↑Thu Dec 06, 2018 8:00 amWill surely not even be close. I was calculating a bit with some co workers the other day. Rubber to asphalt
friction coefficient is about 1 according to the net. It might be somewhere near 1.3 with a lot of rubber on the track?? Even if you assume 1,5 coefficient and 1,5 down force to weight ratio on the NSX, which are both high assumptions IMO, they can get to 2,25 G. Not even close to F1.
I think G-force is the one thing quite different on track vs dyno though.
We've been around this discussion before. There are dynoes that can give more than 1G on a gimbal.ian_s wrote: ↑Thu Dec 06, 2018 4:19 pm2G would still give better info than the maximum 1G on a dynoBandit1216 wrote: ↑Thu Dec 06, 2018 8:00 amWill surely not even be close. I was calculating a bit with some co workers the other day. Rubber to asphalt
What has also been discussed at length is sustained G forces. It is extremely difficult to properly simulate accurate sustained G forces on a dyno, most processes involve heavy use of computer estimations from sim programs to fill in the gaps.Craigy wrote: ↑Thu Dec 06, 2018 5:28 pmWe've been around this discussion before. There are dynoes that can give more than 1G on a gimbal.ian_s wrote: ↑Thu Dec 06, 2018 4:19 pm2G would still give better info than the maximum 1G on a dynoBandit1216 wrote: ↑Thu Dec 06, 2018 8:00 am
He's stupid. RB is 2 secs faster than Williams. So is the renault better than the Merc then? How can you be so stupid and still be in F1.GhostF1 wrote: ↑Thu Dec 06, 2018 11:57 pmJust linking another Abiteboul stab that lacks any technical fact. Basically insinuating that because TR finished behind Renault, the Honda PU is obviously worse![]()
https://www.planetf1.com/news/renault-r ... ing-honda/
“Red Bull never tire of telling how good Honda is compared to us.
“May I state that Toro Rosso is still behind us?”
This guy is amazing.
