Page 1 of 2
Replacement F1/WEC Fuel Flow Sensor?
Posted: 29 May 2014, 21:41
by f1jonno
Looks like there may be some new technology on the way to replace the current fuel flow sensor in F1/WEC...http://www.autosportsensors.com/2014/05 ... sor-range/
Re: Replacement F1/WEC Fuel Flow Sensor?
Posted: 29 May 2014, 21:43
by flynfrog
still have no idea why they insist on these sensors when a standard orifice and popoff valve could have done the same thing.
Posted: 30 May 2014, 00:42
by gruntguru
Such a device would set the upper limit but would need additional refinements to taper the flow at lower rpm and also to compensate for fuel temperature.
Posted: 30 May 2014, 04:47
by strad
That link did not work for me...
Formula 1 teams may not have to use the controversial Gill Sensors fuel flow meter for the whole of the 2014 season. It has been revealed that an alternative solution is in the final stages of development and could be homologated by the end of the year.
Most of the original team behind the development of the ultrasonic fuel flow control technology introduced to the FIA Formula 1 World Championship and the FIA World Endurance Championship this season have reunited in a new company, SentronicsTM Limited, to produce a range of second-generation ultrasonic fuel flow sensors, branded FlowSonic, for motorsport and other markets around the world.
Sentronics is a partnership of three British companies, sensor producer Reventec, precision machining firm Mikina Engineering, and electronics specialists Polyhedrus Electronics, plus US-based Hyspeed LLC.
Hyspeed originated the concept of using an ultrasonic flow sensor in motorsport to limit fuel consumption, control peak power, and balance performance in 2009, initially pursuing its development in collaboration with Gill Sensors. The termination of that relationship in early 2013 left Hyspeed seeking other ways to achieve its objectives, eventually leading to formation of the new venture in late 2013.
The new consortium is headed by Managing Director Neville Meech, for 13 years Gill Sensors’ lead motorsport engineer. “Hyspeed approached me after I started Reventec with funding for a new sensor project. Being based at Mikina made it easy to bring them on board to handle manufacturing, and the final piece of the technical puzzle was put in place when we teamed up with Polyhedrus, who brought a cutting-edge approach to the electronics element.”
“We remain convinced that the ultrasonic time-of-flight principle is the best way of measuring fuel flow on board a race car, and with our second-generation sensor we’ve let the demands of the motorsport application have a greater influence over the design. As a result, the FlowSonic is a compact and robust unit with the minimum of materials and parts, and hence less to go wrong,” says Meech. The FlowSonic weighs in at around 250g, half the maximum permitted by the FIA, and the fuel and electrical connectors are also to FIA specification, making it a potential drop-in replacement for the sensor presently used in F1 and WEC.
If homologated by the FIA, Sentronics plans to offer the sensor for F1 and WEC use on very competitive terms and it is thought to be significantly lower cost that the rival product.
The FlowSonic will also be available to other series looking to implement fuel flow control, with capabilities tailored to their requirements and priced accordingly. “Our top-of-the-line sensor will meet the current FIA standard, while our mid-range product targets series like IndyCar, DTM, and Japanese Super GT. Our basic unit is designed for GTs, touring cars, and even one-make categories. We have also approached Calibra Technology, the FIA-homologated calibration service, about adjusting the level and cost of calibration to match the needs of individual championships,” says Meech.
“Reduced design and manufacturing costs, our three-tier product strategy, and accepting a longer-term return on our investment will allow us to expand into more motorsport markets,” says Daniel Partel, Chairman of SentronicsTM. “Neither V8 Supercars nor IMSA can justify F1-type prices for a fuel flow sensor, but they both face the challenge of balancing performance across a large number of engine suppliers. If we can deliver a performance balancing solution that promotes efficiency for less than it costs to decrease efficiency by adding air restrictors, ballast, or drag, then we will be able to serve markets down to F3 and GT3, even Formula 4.”
“We are confident that we have produced a next-generation ultrasonic fuel flow sensor that represents a major improvement in both performance and value. We are also committed to providing the kind of warranty, service, and support that motorsport customers expect. As racers ourselves, we know exactly what that involves,” says Partel. “Now that we are into the final development phase, which includes bench and track testing with OEMs, we will be presenting the FlowSonic to major sanctioning bodies and other stakeholders worldwide over the next few months with a view to adoption for 2015 and beyond.”
READ THE FULL STORY OF THE DESIGN AN DEVELOPMENT OF THE NEW FUEL FLOW METER IN THE LATEST EDITION OF RACECAR ENGINEERING
Posted: 30 May 2014, 05:51
by flynfrog
gruntguru wrote:Such a device would set the upper limit but would need additional refinements to taper the flow at lower rpm and also to compensate for fuel temperature.
Why would it need to taper the flow at low RPM all the FIA care about is max flow rate? Who cares if it doesn't temperature compensate if every body has the same one.
Posted: 30 May 2014, 11:26
by alexx_88
Right now, we'are seeing >10.5k RPM because that's the point when the maximum flow of 100kg/h is permitted. If you'd put just a mechanical restrictor, you won't be able to create a variable flow limit and the engines will use the 100kg/h much earlier and won't rev as high.
Posted: 30 May 2014, 16:05
by flynfrog
alexx_88 wrote:Right now, we'are seeing >10.5k RPM because that's the point when the maximum flow of 100kg/h is permitted. If you'd put just a mechanical restrictor, you won't be able to create a variable flow limit and the engines will use the 100kg/h much earlier and won't rev as high.
I don't follow you? Your variable flow is done at the injectors not the sensor. If you are limited to 100Kg or what ever flow rate you get through an orifice at a pressure you are still limited. The difference is one its much cheaper and more reliable.
Posted: 30 May 2014, 16:41
by Scootin159
The fuel flow rule isn't really "100kg/hr", it's actually a tapered restriction that increases with RPM, finally capping at 100kg/hr at 10.5k rpm. It does make it much more complex to calculate, since the fuel flow limit must take RPM into consideration - but it has the net effect of pushing the engine builders to using more RPM's (otherwise they aren't using the full 100kg/hr allowed).
The other reason a simple popoff isn't used is that a fuel flow meter also allows them to specify the maximum of 100kg fuel used in a race. Obviously this could in theory be enforced by just limiting how much fuel the teams put into their cars - but in practice that would be pretty hard to police (how do we know the car is "empty" before?).
Posted: 30 May 2014, 20:37
by flynfrog
Scootin159 wrote:The fuel flow rule isn't really "100kg/hr", it's actually a tapered restriction that increases with RPM, finally capping at 100kg/hr at 10.5k rpm. It does make it much more complex to calculate, since the fuel flow limit must take RPM into consideration - but it has the net effect of pushing the engine builders to using more RPM's (otherwise they aren't using the full 100kg/hr allowed).
Thanks for the clarification.
my point being it didn't need to be. 100kg/race is pretty easy to measure weight the car before the race weight it after. Instead of spelling out a complicated fuel flow limit simply state a FIA standard orifice must be place XX Cm from the injector rail with no other path to the injectors. Every one has the same orifice. They can be easily checked. They don't require dodgy calibration and offsets. This would have been a much cheaper option than the current methods. Basically the same as an air limited series call out a hole size and be done with it.
Posted: 30 May 2014, 20:44
by Lycoming
Scootin159 wrote:Obviously this could in theory be enforced by just limiting how much fuel the teams put into their cars - but in practice that would be pretty hard to police (how do we know the car is "empty" before?).
It can't be that hard. They do basically this (measure fuel in and subtract fuel remaining at the end to get fuel used) for dozens of cars a weekend at FSAE events.
Posted: 30 May 2014, 21:05
by Scootin159
flynfrog wrote:Instead of spelling out a complicated fuel flow limit simply state a FIA standard orifice must be place XX Cm from the injector rail with no other path to the injectors. Every one has the same orifice. They can be easily checked. They don't require dodgy calibration and offsets. This would have been a much cheaper option than the current methods. Basically the same as an air limited series call out a hole size and be done with it.
This method is still good for measuring volumetric flow (limiting pressure through a given orifice), but doesn't take into account temperature. If a team were to implement a fuel cooler, they could get more mass of fuel through the orifice at the same pressure. You could certainly write a rule that prohibits actively cooling the fuel with a refrigerant, but you couldn't prevent the teams from passively cooling the fuel (which they'd be silly not to since it would be so closely tied to horsepower).
I still feel a simpler method of metering the fuel is a good idea, but a simple orifice "valve" isn't enough. Maybe if the valve had a pop-off pressure regulator that was temperature compensated? You'd also need to have a max fuel pressure limit (which is reasonably above the pop-off pressure) to prevent teams from just overloading the pressure regulator by hitting it with massive amounts of fuel pressure - although that would be easy to do.
Does anyone know how the rules prohibit a team from implementing a collector on the post-meter side of the fuel rail? If a team had a fuel rail with 1 liter of volume, they could effectively get around the entire 100 l/h flow limit and use as much peak fuel flow as they want.
Posted: 30 May 2014, 21:12
by Scootin159
Scootin159 wrote: Does anyone know how the rules prohibit a team from implementing a collector on the post-meter side of the fuel rail? If a team had a fuel rail with 1 liter of volume, they could effectively get around the entire 100 l/h flow limit and use as much peak fuel flow as they want.
Answering my own question:
5.10.5 wrote:Any device, system or procedure the purpose and/or effect of which is to increase the flow rate after the measurement point is prohibited.
I suspect that having a fuel pressure regulator after the fuel flow meter would violate this rule.
Posted: 30 May 2014, 21:45
by Lycoming
mm... I would think not as long as it's mounted in series.
Posted: 30 May 2014, 22:28
by flynfrog
If a team wants to drag around the weight of a fuel cooler who cares let them. Its open to all other teams. Get rid of the exact flow requirement and focus the rule on the restrictor. The sensor seems like a $1000 solution to a $10 problem.
Posted: 31 May 2014, 02:51
by wuzak
Fuel density varies with temperature, but also with the fuel supplier. Potentially a simple restrictor would need to be made for each team, and for each fuel specification (which could be several) they use during the season.
The Gill sensor is a volumetric flow meter, but software corrects for temperature and fuel density.
Weighing the car before and after the race would be valid if the maximum fuel capacity allowed was 100kg. The fuel limit is, in fact, 100kg from lights to flag. That means that the car can do 15 minutes worth of reconaissance laps (ie when exiting the pits for the grid they have the option of driving through the pit lane and doing another lap), as many warm-up laps as required (if a car stalls on teh grid, they do another lap), and the cool-down lap, including as many burnouts as the winning driver may feel like doing (now that is no longer frowned upon).
Reconnaissance laps ae the most significant, because they can run at almost race speeds around the track.
