Mercedes AMG F1 W06
Post Reply
adrianjordan
Re: Mercedes AMG F1 W06 Speculation
Facts Only wrote:...variable length inlet trumpets.
Please could someone explain these in (as) simple (as possible) terms as they're a new concept to me...
Favourite team: McLaren
https://www.youtube.com/watch?v=MRZW31F7McY
Harry_F1Fan
New bodywork over the side pods
Emerson.F
:o
Supporting: Ham/Alo/Kimi/Ros/Seb/Hulk/Ric/Mag
dren
226
Nice view of the sidepod winglets. Very detailed.
Honda!
henra
GPR-A wrote: I am only debating the WIDTH of the nose structure. McLaren HAS a wide nose and Merc has opted for much leaner nose. Not sure why? When Merc knows the answers to creating such a complex nose, why are they going for leaner one, when in reality they could still have been aggressive.
With the new Nose regulations the tip is very low. When you go for a wide nose it is difficult to get enough undisturbed air to the tray and floor area. Squeezing it underneath a wide nose and through the Front Wing pillars will rob the air much of its velocity which is not good for underbody aerodynamics.
One way to get a bit around this problem is to force it alongside the nose. Ferrari does that with aggressive rounding, a very long nose and extreme toe-out of the Front Wing pillars. Merc seems to pursue a very similar path, just executed differently. As an advantage for the Merc Approach I see a bigger distance to the Y-250 vortex. With the Ferrari Approach (also last year's) getting no interferences of both flows might be a bit of a challenge.
McLaren seems to try something a little bit different but I haven't figured out what, yet.
SectorOne
Could the shorter nose also have anything to do with crosswinds?
So with a shorter nose it will not affect the front wings as much?
Probably a bad image as it seems the air is going the opposite direction of what i had in mind.
Advino116
19
SectorOne wrote:Could the shorter nose also have anything to do with crosswinds?
http://i.imgur.com/CM1eAqp.png
The image depicts the air flow in the case the car spins. I recognised it from a video that was shown during a talk by Sauber's TD at my university.
astracrazy
31
I don't know about anyone else, but i'm half looking forward to seeing what the w06 front wing will be like - if we get a change at all. The w05 wing was a thing of beauty.
I see where your coming from but if it was a major factor of consideration then they would all have short noses. From that image, it looks like air going over the endplates would be more of a problem anyway (in that scenario)?
I tend to think keeping with a short nose was the best next thing, within the rules, to the w05 nose. To keep more of an evolutional step. From the side, the look nearly identical in angle/shape (atleast launch w05 spec)
kooleracer wrote:But this isn't the new chroma livery that they have been talking about right?
I was expecting Mclaren chrome maybe its because its just a really dull day. Get some sunshine on her and we'll see. From the very first pics you can see its more chrome
SectorOne
Advino116 wrote:The image depicts the air flow in the case the car spins. I recognised it from a video that was shown during a talk by Sauber's TD at my university.
My bad, so in the real world airflow is more or less always hitting the car head on?
astracrazy wrote:I see where your coming from but if it was a major factor of consideration then they would all have short noses.
Yea i had this little idea that simply accomplishing a short nose was so exhaustive in terms of R&D that most teams simply say forget it. Anyway forget it :)
Artur Craft
40
SectorOne wrote: My bad, so in the real world airflow is more or less always hitting the car head on?
of course not. But crosswinds are not that much of a significant factor when designing your car as it is sort of an once in a while thing.
3m/s(typical values) wind won't affect aerodynamics that much.
They design more with yaw effect(happens in cornering) in mind and consideration.
My guess is that a longer nose will have a different effect during yaw condition airflow but to quantify it we would need CFD analysis.
f1motta
64
Mercedes W05 vs. W06 - front view - http://www.f1talks.pl/mercedes-w05-vs-w06
fawe4
Nose, after suspension, drops for a lot and is almost tinny compared to other teams. I've not idea how the managed to package that.
Post Reply
