I don't understand, how would this work exactly ?
You mean the budget allocation part or the testing part?
It's a simplification, but if that's what the data says, yeah
They re-hire them from the same team that just dumped them because they were in the opposite position? Or they retrain them? This scheme only makes sense in a budget cap future where some degree of personnel movement is baked into the system and they know how to do forensic accounting across teams with complicated PU and chassis department splits.Mudflap wrote: ↑Sun Jul 19, 2020 8:14 pmI see your point but the problem with this is that the PU and chassis sides of the bussiness are often independent.
Imagine if Red Bull had to lay off 50% of workforce just because FIA deems their aero good enough. What happens in say 2 years when someone catches up with them on the chassis side ?
‘Oil overfill!!!’. Mercedes mechanics should be more careful and not ‘overfill’ their engine crankcase ha ha ha.zibby43 wrote: ↑Sat Jul 18, 2020 10:52 pmRe: the puffs of smoke, it could be a number of benign things, to be honest. Oil overfills are most commonly the cause of initial puffs of smoke, which would explain why they happen early in a session.
And this overfill situation could also be related to packaging, which is why it's also seen on the customer cars.
On a side note, Toto Wolff responding to Mattia's comments about the TDs impacting all teams:
He goes on:
- “Another complete bullshit story, technical directives.
“There’s a clear regulation on power units, there have been clarifications in Austin what you are allowed to do or not which were important.
“But nothing that was in any way surprising because if you comply to the regulations that was clear anyway.”
https://the-race.com/formula-1/wolff-ex ... nic-gains/
- "“I think the irony of the story is that we were pushed by some of our competitors to absolutely new levels,” said Wolff.
“It brought us to almost burnout last year to develop and innovate in a way to be competitive on track.
“And here we go. I think we made a substantial jump in performance from 2019 to 2020 because we needed to last year and that is a little bit ironic for me.”
Highly overestimated, and especially at this point in the development. They are now scratching for every minuscule amount of extra power they can squeeze out of the systems, trying to maximize everything. They may have goals, but they are just taking what they can get at this point.rgava wrote: ↑Sat Jul 18, 2020 8:53 amEngineering targets are very important.jumpingfish wrote: ↑Sat Jul 18, 2020 8:19 amBut what will they do with that information if for example SF1000 has more drag than W11 and Mercedes has more powerful engine?
If you know exactly were your rivals are, you have clear development targets for your team.
I posted the table in the Red Bull thread but here it is:casper wrote: ↑Wed Jul 15, 2020 11:36 amI came across a table used in Detailed Hydrocarbon Analysis method for quantifying the organic homologues: paraffins, isoparaffins, olefins, naphthene, olefins, aromatics, and oxygenates. The table lists organic compound with their Octane numbers, with some higher than MTBE's (the first additive that replaced tetra ethyl lead, but subsequently banned too). Can I post it here?
brilliant !!casper wrote: ↑Fri Jul 31, 2020 7:56 pmI posted the table in the Red Bull thread but here it is:casper wrote: ↑Wed Jul 15, 2020 11:36 amI came across a table used in Detailed Hydrocarbon Analysis method for quantifying the organic homologues: paraffins, isoparaffins, olefins, naphthene, olefins, aromatics, and oxygenates. The table lists organic compound with their Octane numbers, with some higher than MTBE's (the first additive that replaced tetra ethyl lead, but subsequently banned too). Can I post it here?
Compound no. of C I RRF BP, C MW MON RON VP Density HC
iso-butene 4 382.4 0.842 -6.9 56.1 139 170 64.58 0.6013 iO
1-buytyne 4 386.9 0.8431 8.1 54.1 130 180 41.05 0.6959 nO
1,3-butadiene 4 394.4 0.8431 -4.4 54.1 140 190 59.29 0.6273 dO
t-2-butene 4 406.9 0.8742 1 56.1 130 153 49.88 0.6112 nO
c-2-butene 4 418 0.8742 3.7 56.1 130 153 45.75 0.6286 nO
ethanol 2 434.32 1.862 78.3 46.07 102 126 2.31 0.7967 Ox
1,2-butadiene 4 436.6 0.8431 10.9 54.1 135 185 36.77 0.6576 dO
2-butyne 4 482 0.8431 27 54.1 150 200 41.05 0.6959 nO
iso-propanol 3 487.4 1.95 82.2 60.11 100 120 1.84 0.7925 Ox
2-m-1-butene 5 493.76 0.8739 31 70.1 133 146 18.41 0.6563 iO
t-2-pentene 5 505.9 0.8739 37 70.1 134 150 15.44 0.6524 nO
c-2-pentene 5 512.4 0.8739 37.5 70.1 137 154 15.13 0.6598 nO
2-m-2-butene 5 516.6 0.8739 36.5 70.1 141 176 14.31 0.6683 iO
t-1,3-pentadiene 5 518.8 0.849 42 68.1 160 180 12.71 0.676 dO
3-m-1,2-butadiene 5 529 0.849 40.8 68.1 160 180 13.2 0.6916 dO
cyclopentadiene 5 529.83 0.824 41.5 66.1 200 220 0 0.8041 cO
c-1,3-pentadiene 5 534.9 0.849 44.1 68.1 160 180 11.82 0.6964 dO
1,2-pentadiene 5 536.7 0.849 44.9 68.1 160 180 11.49 0.6976 dO
cyclopentene 5 548.2 0.849 44.2 68.1 160 180 11.78 0.7773 cO
2,3-pentadiene 5 557 0.849 48.3 68.1 160 180 10.14 0.7001 dO
cyclopentane 5 560 0.8727 49.3 70 141 141 9.92 0.7603 N
MTBE 6 563.6 1.4067 55.2 88.148 104 148 7.97 0.7458 Ox
2-m-2-pentene 6 607.3 0.8747 67 84.2 148 159 6.3 0.6909 iO
3-methylcyclopentene 6 612.35 0.8529 64.9 82.1 160 180 0 0.7854 cO
4,4-dimethyl-1-pentene 7 628.2 0.8744 72.5 98.2 136 144 1.39 0.6872 iO
2,3-dimethyl-2-butene 6 634 0.8747 73 84.2 144 185 4.16 0.713 iO
3-methyl-1,5-hexadiene 7 644.1 0.8566 88.1 96.2 160 180 0 0.7234 dO
1,4-hexadiene 6 649 0.8322 65 82 160 180 7.09 0.7198 iO
1-methylcyclopentene 6 649.55 0.8529 75.5 82.1 160 180 0 0.7854 cO
benzene 6 650.4 0.8103 80.1 78 91 99 3.21 0.8829 A
3,3-dimethyl-1,4-pentadiene 7 665.2 0.8566 88.1 96.2 160 180 0 0.7712 dO
2-m-1,5-hexadiene 7 675.5 0.8566 88.1 96.2 160 180 0 0.7234 dO
2,3-dimethyl-1,3-pentadiene 7 693.3 0.8566 93.2 96.2 160 180 0 0.7712 dO
Toluene 7 757.68 0.8192 110.6 92 112 124 10.03 0.8743 A
3,4-dimethylhexane 8 772.5 0.8586 114.3 114.2 160 180 0.66 0.7015 I
ethylbenzene 8 852 0.8259 136.1 106 107 124 0.37 0.8744 A
m-Xylene 8 858.3 0.8259 139.1 106 124 145 0.33 0.8694 A
p-Xylene 8 860.7 0.8259 138.4 106 127 146 0.35 0.8666 A
iO Iso Olefin
nO normal Olefin
dO di-Olefin
Ox Oxygenate
cO cyclo Olefin
N Naphthene
I isoParaffin
A Aromatics
thanks casper ...
