[MVRC] Mantium Virtual Racecar Challenge 2016
rjsa
rjsa
51
Re: [MVRC] Mantium Virtual Racecar Challenge 2016
The MVRC site is down. You guys really going to publish the new challenge when I'm ten days away from my workstation, right?
rjsa
rjsa
51
It's back. My bad.
LVDH
38
When I read this I almost had a heart attack. Are you crazy?
rjsa
rjsa
51
Anxious.
CAEdevice
rjsa wrote:
Sat May 13, 2017 6:11 pm
Anxious.
Me too :)
LVDH
38
Yes, me too. We are getting close. I guess the next email from Chris will mark the new rules and I am about to release the new software. And there is a geometry generator getting ready as well. That one will be very useful for the intro class.
CAEdevice
LVDH wrote:
Mon May 15, 2017 11:04 am
I am so curious about the new software and the new mesh settings.
Alonso Fan
I simply cannot wait any longer...
SHR Modding
Youtube
Twitter
Discord
Sound Developer for Reiza Studios
Sound Modder for Assetto Corsa
CAEdevice
Alonso Fan wrote:
Mon May 15, 2017 11:33 pm
The launch of your cars is the best without any doubt =D>
CAEdevice
I would like to point out that the standard installation of OF 1606+ on Windows doesn't work anymore after upgrading to Windows 10 Creators Update.
Code: Select all
C:\Program Files (x86)\ESI\OpenFOAM\1606>"C:\Program Files (x86)\ESI\OpenFOAM\1606\Windows\Scripts\of_start_container.exe" -Arguments "C:\Program Files\Docker Toolbox\;C:\Program Files\Git\bin"
Starting "default"...
Machine "default" is already running.
Error checking TLS connection: Error checking and/or regenerating the certs: There was an error validating certificates for host "192.168.99.100:2376": open C:\Users\Amministratore\.docker\machine\machines\default\server.pem: Impossibile trovare il file specificato.
You can attempt to regenerate them using 'docker-machine regenerate-certs [name]'.
Be advised that this will trigger a Docker daemon restart which will stop running containers.
An error occurred trying to connect: Post http://%2F%2F.%2Fpipe%2Fdocker_engine/v1.23/containers/of_plus_1606/start: open //./pipe/docker_engine: Impossibile trovare il file specificato.
Error: failed to start containers: of_plus_1606
An error occurred trying to connect: Post http://%2F%2F.%2Fpipe%2Fdocker_engine/v1.23/containers/of_plus_1606/exec: open //./pipe/docker_engine: Impossibile trovare il file specificato.
Stopping "default"...
It looks there is problem with Docker (and a small issue with VirtualBox too)
Alonso Fan
CAEdevice wrote:
Tue May 16, 2017 2:34 pm
Thanks, you are too kind :)
SHR Modding
Youtube
Twitter
Discord
CAEdevice
Hi, what about the calendar? How many races have been planned? I would not mind more time between the races than last year.
Alonso Fan
CAEdevice wrote:
Sat May 27, 2017 1:47 pm
I would also welcome more time between races
SHR Modding
Youtube
Twitter
Discord
LVDH
38
Hi guys,
there is a new calender and I worked on the homepage. The plan is to finish and test the new software next Wednesday. So with some luck I will make everything available next weekend. As soon as Chris and Richard agree on the proposed calender, I can release it before publishing the new homepage. One small thing that will be different is that I have closed the old support forum. It is only there to not loose the gathered knowledge. There will be a new system similar to Stack Overflow. I hope it will be a bit better and one thing that will for sure be better is that I will get an email notification when someone posts a new question. This should improve response times.
And we will probably have a new team from Southampton. Looking forward to Coburn Racing.
Hang tight and don´t worry, as we will probably start July 9th and end December 10th there will be more time this year, although I am bit disappointed about me because we are once more starting a bit late into the year.
CAEdevice
Thanks for the update and for improving the challenge.
Welcome to the new team!
I can't wait to see the cars (and to know which layout the teams will choose).
