Scuderia Ferrari SF71H
Post Reply
Santozini
Re: Scuderia Ferrari SF71H
dren wrote:
08 Mar 2018, 14:20
This was in the testing thread:
Can someone highlight where exactly is the sorcery? :?
k.ko100v
Santozini wrote:
08 Mar 2018, 14:54
dren wrote:
08 Mar 2018, 14:20
https://pbs.twimg.com/media/DXmHlgNW4AAJX0v.jpg
It should be those exits
Dipesh1995
104
Santozini wrote:
08 Mar 2018, 14:54
dren wrote:
08 Mar 2018, 14:20
The opening directly below the wastegate pipes I think.
Contact:
Look at the tunnel on the floor under the exhaust and rear crash structure.
#Aerogimli
Mr.G
34
The exits are old, no? I would say is where the light ends and the shadow is starting... it looks like two "levels" of the floor...
gandharva
252
Remember, remember...
Mr.G
34
Mr.G wrote:
08 Mar 2018, 15:03
EDIT - Or is that part I'm thinking of the RW support?
Santozini
Thanks guys, wow, that's quite visible actually! :shock:
Could it be outside the rule book?
Owen.C93
171
Gerhardsa
From this pic, it doesn't look like a double diffuser type setup. Its difficult to say, but I don't see any openings
Maybe someone can lighten up the pic a bit. maybe we can see better then
f300v10
185
Scarbs commented on this last week. He believes the duct is simply to contain/channel the airflow coming from the coke bottle section and guide it towards the central part of the top of the diffusor. The goal is to maximize the flow over the taller part of the Gurney flaps centered under the crash structure. There is no gaping hole in the Ferrari floor as there was during the double diffusor days.
From Scarbs F1 DriveTribe page:
"There is then the dip in the middle of the diffuser, this boat-tail shape is where the stepped underfloor sweeps up to meet the rest of the diffuser. Teams direct airflow around the sidepods into the boat tail to drive the taller gurney flaps allowed in the middle of the diffuser. Already Ferrari added various flaps and vanes guide airflow, but the new car has a coved bodypanel to enclose the boat tail against the gearbox/crash structure. This prevents the pressure building up in the boat tail from spilling upwards over the wide sections of the diffuser."
https://drivetribe.com/p/f1-what-update ... bNAqOmClog
OO7
OO7
171
f300v10 wrote:
08 Mar 2018, 15:17
The exit appears to be significantly larger than the entrance, so would have a diffuser like effect of the air exiting. I can't see how that would be helpful. Also I would expect it to compromise the rest of the diffuser (top surface) more than any benefit it may bring.
Contact:
Blaze1 wrote:
08 Mar 2018, 15:28
That's exactly the point, to allow the air to expand and increase pressure on top of the diffuser in a controlled fashion.
It will be interesting to see if there's some hot air from around the engine as well. On one hand, it's turbulent air. On the other hand, it's hot and has higher energy.
#Aerogimli
OO7
OO7
171
Vanja #66 wrote:
08 Mar 2018, 15:32
Blaze1 wrote:
08 Mar 2018, 15:28
If the air is expanding in the expected fashion, wouldn't this reduce pressure over the diffuser rather than increase it.
Contact:
Blaze1 wrote:
08 Mar 2018, 15:35
Does the pressure in diffuser decrease or increase when air starts to expand?
#Aerogimli
Post Reply
