Mercedes AMG F1 W09 EQ Power+
Re: Mercedes AMG F1 W09 EQ Power+
Mercedes are using a camera camera to check the flexibility of the area, currently has metal reinforcement (Via @AlbertFabrega)
Ishwar030
Ishwar030
zac510
zac510
22
In these pictures I note that the W08 seems to have some ducting exit around the exhaust pipe, but the W09 does not. This might explain why the W09's exit ducting appears to have a greater area.
George-Jung
George-Jung
zac510 wrote:
27 Feb 2018, 19:32
Waste gates; W09 has them too- have a closer look.
Mandrake
Mandrake
ScrewCaptain27
577
They are indeed, and that’s worrying with such low temperatures.
- Serj Tankian
ScrewCaptain27 wrote:
27 Feb 2018, 20:36
Is it really a proper indication though? The weather isn't really helping, and probably gives some skewed results
CBeck113
CBeck113
51
27 Feb 2018, 20:36
It's not, actually - the tires are being operated in a temperature window far below their intended specifications, so it is normal and expected
27 Feb 2018, 20:36
It's not worrying at all, the reason they're blistered is because of such low temperatures that they can't get the tyres working #-o
Anyone looking at either times, or tyre wear, in the past few days with temperatures so far out of their working range needs a bang on the head :wtf:
zac510
zac510
22
George-Jung wrote:
27 Feb 2018, 20:22
zac510 wrote:
27 Feb 2018, 19:32
Sorry I don't know what you mean - the wastegate itself is attached to the turbine housing or the manifold. Do you mean the wastegate pipes?
Either way the bodywork is tight around the W09 exhaust pipe and wastegate pipes and not on the W08. And yes I did have a closer look, reviewed some photos from last year!
George-Jung
George-Jung
zac510 wrote:
27 Feb 2018, 22:44
George-Jung wrote:
27 Feb 2018, 20:22
zac510 wrote:
27 Feb 2018, 19:32
Than my bad, misread your initial post.
zac510
zac510
22
George-Jung wrote:
27 Feb 2018, 22:58
zac510 wrote:
27 Feb 2018, 22:44
George-Jung wrote:
27 Feb 2018, 20:22
No problem :)
bonjon1979
bonjon1979
30
Anyone want to work out the exact wheelbase of the Mercedes, here's your chance! The yellow lines mark the exact position of the axles and there's a handy scale on the yellow line to work out the length. Should be able to do this with all the cars that have had a pitbox photo taken. I'd do it myself but I'm in the middle of some work!
https://imgr4.auto-motor-und-sport.de/V ... 149305.jpg
