[CFD] Calculating Initial Conditions for Turbulence
Snail With a Shotgun
Re: [CFD] Calculating Initial Conditions for Turbulence
Thanks a lot Vyssion, I've been running quite a few simulations lately and your explanation was very helpful :wink: .
That said, something doesn't feel quite right and I think turbulent intensity might be to blame. A friend of mine told me to use turbulent intensity of 0.1%, which seems too low to me (AFAIK even the most advanced wind tunnels can only go as low as 0.5% (?)). Could you please shed some light on what values one might want to use for automotive use and when to use them?
Vyssion
Moderator / Writer
Snail With a Shotgun wrote:
12 Aug 2022, 19:06
Sounds like your friend is having issues with convergence, and has "hacked" it by just switching turbulence so close to "off" it doesn't matter :lol:
Your numbers aren't too far off. Default for most CFD is usually set at 5%. Depending on what it is you're analyzing, that can sometimes be a little high, and you might want to opt for say 2-3% as a standard. 1% would be quite low turbulence, but wind tunnels can get down to 0.5% yes, and even below that too.
What exactly "doesn't feel right" in your simulation?
#aerosaruman
