2018 United States Grand Prix - Austin, 19-21 October
dans79
252
Re: 2018 United States Grand Prix - Austin, 19-21 October
I'm note sure Vettel understands how rules and specifically red flags work.
Someone should remind him that you slow down first, then have a look around!
https://www.motorsport.com/f1/news/vett ... g/3198181/
"I think there should be common sense with the rules that we have," said the Ferrari driver. "I think lining out 27.7 seconds precisely as not complying with the rules I think is wrong.
"I think I slowed down, I had a good look around at what was going on. The rules are clear so we know.
"It is the first time we had this in the wet, where the target is a lot slower, so literally you have to stop to 40-50km/h to bring down the delta, which probably I should do next time.
"But in my opinion that is not the right thing. If there is a car right behind you, it might run into you. But it is more important you don't get a penalty."
Vettel said he explained to the stewards that he had seen the red flag when it came out, and he reacted once he had checked there was no danger.
"They [the stewards] were very specific, saying I took 27.7 seconds to slow down," he explained.
"I saw the red flag, I slowed down, I had a look around where the car was potentially stuck in the wall or if there was one around Turn 9 or 10. Then I slowed down significantly to comply with the rules.
"They found it too long. I think it was straightforward.
"On top of it there might have been an issue with the timing, the system. I don't know. So...I slowed down."
191 103 103 7
GrandAxe
GrandAxe
A four time WDC taking half a minute to slow down for a red flag ... Erm, what was Vettel thinking? #-o
How one man can create so many negative drama's without help from his adversaries is a mystery. It's become a real comedy show. Oh well, some mothers do have 'em. :lol: :lol:
subcritical71
90
Marshaling light 5 is off, the first one on is marshaling light 6, he seems to slow, but even if he didn’t, shouldn’t there be at least a one sector freebie? I can’t see the warning lights on the steering wheel activate, so I don’t know how much advanced warning he had.
Reading dans79 quote, I didn’t see a 27.7 second delay in his slowing down.... but really, is Seb complaining somebody might run into the back of him :twisted: :D
GrandAxe
GrandAxe
NathanOlder wrote:
Fri Oct 19, 2018 8:35 pm
Horner reckons the 3 place penalty for speeding under a red flag is a rubbish rule, and the best way to hurt a driver is to give him a fine. Most of these drivers are millionaires, a fine does not hurt them. A sporting penalty hurts them way more. Stop talking rubbish Horner.
You want a grown man to give up his hobby? :D
dans79
252
subcritical71 wrote:
Fri Oct 19, 2018 10:38 pm
The way I read the stewards report, he was below the target time in marshaling sectors 6 and 7. He would probably have gotten off if it was just sector 6, but not 6 and 7.
191 103 103 7
subcritical71
90
dans79 wrote:
Fri Oct 19, 2018 10:45 pm
Ah, I see the bolded part now. But man he was already quite slow from the onboard in 6 and 7. He’d go into antistall to go any slower.
Juzh
153
dans79 wrote:
Fri Oct 19, 2018 10:33 pm
Someone should remind dans79 that you have to first understand something you just read before you write nonsense about it.
"I saw the red flag, I slowed down , I had a look around"
and it's quite obvious from the onboard he slows down A LOT. just not to like 40-50 kmh like the ridicioulus rules say he should.
GrandAxe
GrandAxe
Bottas was on a cracking lap and had just set fastest sector times (even through the gravel on track), yet he could respond to the red flag and slow down on time, while Vettel who had been doing granny laps all day somehow couldn't find his brake pedal when it really mattered.
LeClerc
FIA sporting regulations 31.6...
https://www.fia.com/file/74025/download ... n=8Dk4HzgE
It does not matter if Vettel thinks he slowed down, all that matters is if he slowed down according to standards set by FIA.
It is I, LeClerc!
Phil
66
Yes, i am sure significantly braking is entirely safe in wet conditions...
#Team44 supporter
LeClerc
Phil wrote:
Fri Oct 19, 2018 11:18 pm
Come on!
It's not like he would have had to brake to not be above the limit.
Our last hope of a challenge lost because he couldn't be bothered to slow enough.
As our friend Vettel would say: "Honestly?"
It is I, LeClerc!
dans79
252
Juzh wrote:
Fri Oct 19, 2018 11:09 pm
I know exactly what I read. vettel's explanation is like "I took my foot off the gas, looked around and then decided to use the brakes”
call the rule whatever you want, but it's been in place for nearly a year he should know better!
The proper way to follow the rule is as soon as you see the red lights, you slow the car down to the delta time!
191 103 103 7
Why not ditch that whole delta thing and tell the drivers to slow down fast but safely and use the pit limiter to drive to the pits :P
RZS10
355
That would essentially be the slow zone system the WEC uses, no?
