Scuderia Ferrari SF90
Post Reply
Re: Scuderia Ferrari SF90
https://twitter.com/AlbertFabrega/statu ... 01539?s=20
Presumably an attempt to add front end downforce. Looks like a mini car underfloor below the nose.
Via @andihaupt1
Vertical fins on the floor too
Along with revised ones in front of the rear wheels
Ashwinv16
58
Contact:
2008 said hello, hope it doesn't disrupt flow into the floor
Halo not as bad as we thought
timbo
111
I thought you have to create a twist in the channel so the you cannot see through, am I wrong?
f1316
78
It’s basically a mini cape behind the new nose - interesting that they still chose not to extend the cape further ala Mercedes et al; you’d think there’d be some dirty downforce available in doing that.
Mamba
timbo wrote:
19 Sep 2019, 14:06
I think the Ferrari nose already meets the two cross section regulation thus this is only an add-on below the nose structure. The RP & Alfa noses employ a trick in the regulations to include those slots in the structure but they still have to comply with the cross-section rules & enclosed surface rule (?), thus they cannot be "see through" like here.
My reasoning at least...
lio007
314
Some nice shots:
AMuS
Ashwinv16
58
Contact:
f1316 wrote:
19 Sep 2019, 14:45
But drag too, a lot of it.
Singapore rear wing
Via AMuS
A nice close-up of the steering wheel
zibby43
613
It's not exactly new, now i believe it's been introduced in Hungary together with the new barge boards, but definitely flown under the radar in this topic is the new(ish) support for the X-vane (black element connecting the X-vane to the crash structure).
f1316
78
Ashwinv16 wrote:
19 Sep 2019, 16:32
f1316 wrote:
19 Sep 2019, 14:45
Which I wouldn’t expect them to be concerned about in somewhere like Singapore.
f1316 wrote:
19 Sep 2019, 14:45
It's point isn't to create downforce per se, but rather create a vortex. For example Mercedes has the cape much longer than everyone else, but they also don't run the vertical elements under the nose.
Post Reply
