OO7
OO7
171
Re: 2022 Aerodynamic Regulations Thread
jjn9128 wrote:
Sun Feb 20, 2022 11:12 am
dxpetrov wrote:
Sun Feb 20, 2022 10:58 am
Probably it has been discussed before, apologies for that, but do we know what happens to rear wings during the season? Do they stay the same specs irrespective of downforce level requirements of different tracks?
No you can change wings - but what is presented for scrutineering has to be carried through a race - so no DF level changes after Friday AM.
What! You can't change D/F levels after the FP sessions?
OO7 wrote:
Sun Feb 20, 2022 11:36 am
:shock: :o :o :shock:
Stupidity.... ](*,) ](*,) ](*,)
jjn9128
762
You can't change the car configuration - so the wing spec you run in the race has to be the same as scrutineering. You can change flap angles and try out different wings in practice but have to put on the scrutineering spec for parc ferme and beyond.
#aerogandalf
Stu
jjn9128 wrote:
Sun Feb 20, 2022 11:42 am
That does make sense, with a budget cap, to remove the ‘test-session’ element of free-practice.
Calculation, correlation, race.
OO7
OO7
171
That's pretty silly in my opinion. The teams should be allowed to alter D/F levels (change rear wing specs) up until the cars leave the garage for Q1.
OO7
OO7
171
Stu wrote:
Sun Feb 20, 2022 11:49 am
With a budge cap, it should be up to the teams to manage their budgets as they see fit.
Tzk
Tzk
32
Where exactly is this stated? I had a look at the latest revision of the sporting regulations and found nothing obvious which bans wing changes before Q or sprint starts. Am i missing something?
I had a look at these:
https://www.fia.com/sites/default/files ... -02-18.pdf
OO7 wrote:
Sun Feb 20, 2022 11:51 am
They can. Parc ferme begins once the cars leave the pits in Q1.
dxpetrov
dxpetrov
-7
Somehow I dont believe these wings would change much, if at all! It's not like before when u had the end plates and just be able to change piece in between. Even not sure if they would be able to change the wing angle. This all looks one single rigid structure.
djos
108
dxpetrov wrote:
Sun Feb 20, 2022 12:15 pm
Most teams can adjust the top two flaps or top flap without changing the wing.
"In downforce we trust"
OO7
OO7
171
Tzk wrote:
Sun Feb 20, 2022 11:56 am
I can't find it either. :?:
jjn9128
762
Looks like it's been deleted from the latest version of the sporting regs
31.5 The bodywork (excluding radiators) of each car as presented for initial scrutineering will establish the Reference Specification and, with the exception of work permitted by Articles 5.4.2 j and v to x, the car must be returned to this specification before the start of P3. The procedure to establish conformity with this article is described in the Appendix to the Technical and Sporting Regulations.
#aerogandalf
west52keep64
51
Do the regs permit a suspension keel? The volumes for bodywork would make it difficult, but could the keel be classed as part of the suspension arms?
Alternatively, could the front suspension arms connect to the splitter? Specifically the rear leg of the lower arms?
jjn9128
762
west52keep64 wrote:
Sun Feb 20, 2022 3:21 pm
Keels are aerodynamically inferior to joining the suspension to the sides of the tub high up - I don't think the rules prohibit a keel but it might be hard in the rule boxes...
#aerogandalf
The leading edge floor fences seem to have a best design, with only minor variations to work with the rest of the aero package. You want the outer fences to build as much pressure as possible, which is why the teams have a downward sloping outer edge. It gives you more surface area for the outer fence, and helps channel more air over the floor, it also helps raise the pressure on the outer strakes creating a greater pressure difference in the wider more open section. Then an inner strake that hugs the legality box to guide that fast low pressure air into the tunnel.
