I’ll figure that out. It’s jut too little time I have & I was counting on throwing it in and be ready. I’m not sure I’ll have a complete, legal car with at least one sim done - that wll have to do for the 2 first races.
Schedule was too tight.
I just checked the code. Are you sure you are not using one of the MVRC templates? If so, the limit should be disabled.rjsa wrote: ↑Thu Aug 08, 2019 5:01 pmHi there, mflow is culling geomery:
"current file name: Z_Suspension_frt_V01.stl
current file name: Z_Suspension_rr_V01.stl
current file name: Z_Wheels_frt_V01.stl
current file name: Z_Wheels_rr_V01.stl
The demo version of MantiumFlow only accepts a maximum of 30 stl files!
Everything above that will not be used for this simulation."
Warning: MantiumFlow could not find the configured blueCFD installation path. right now it is set to: C:\Program Files\blueCFD-Core-2017 Warning: Rear wheels seem to be positioned incorrectly. In MVRC they should be in global (3.4,0,0). Warning: MantiumFlow could not find the configured blueCFD installation path. right now it is set to: C:\Program Files\blueCFD-Core-2017 Warning: Rear wheels seem to be positioned incorrectly. In MVRC they should be in global (3.4,0,0). writing case: E:\CFD\2019f1_mk01_0001
60803 wall MVRC_bool_reduced_patch60794 60804 wall MVRC_bool_reduced_patch60795 60805 wall MVRC_bool_reduced_patch60796 60806 wall MVRC_bool_reduced_patch60797Seems to be on and endless loop.
Time = 1200 forceCoeffs forceCoeffs write: Cm = 0.27190957 Cd = 1.1457955 Cl = -1.63347 Cl(f) = -0.5448254 Cl(r) = -1.0886445
Time = 1200 forceCoeffs forceCoeffs write: Cm = 1.366718 Cd = 1.1547571 Cl = -1.4156811 Cl(f) = 0.65887749 Cl(r) = -2.0745586The first one is the standart MVRC option. Second one is the MVRC_Fast option with same car. I think this is a serious thing since i often use the fast option for quick results.
What is the point having a fast option if it gives complete different results than the full one? I don't think that's normal. I dont know what changed as settings but i always used the fast option on the previous years software (even on my F1 car) and i never got a positive lift value.
I agree, it is not useful. I edited the mesh setting manually in order to obtain a compromise.Ft5fTL wrote: ↑Fri Aug 09, 2019 7:56 pmWhat is the point having a fast option if it gives complete different results than the full one? I don't think that's normal. I dont know what changed as settings but i always used the fast option on the previous years software (even on my F1 car) and i never got a positive lift value.
Why "Time = 1200"? Iterations in "fast" go up to 2000; in "normal" even more, probably. Given the different settings between "normal" and "fast", i don't think that residuals compare. Let them converge and then lets see what happens.Ft5fTL wrote: ↑Fri Aug 09, 2019 7:27 pmI finished my first couple of cfd's with the new software and my new cpu. There is some significant difference on the results that i got from different cfd options.
Time = 1200 forceCoeffs forceCoeffs write: Cm = 0.27190957 Cd = 1.1457955 Cl = -1.63347 Cl(f) = -0.5448254 Cl(r) = -1.0886445Time = 1200 forceCoeffs forceCoeffs write: Cm = 1.366718 Cd = 1.1547571 Cl = -1.4156811 Cl(f) = 0.65887749 Cl(r) = -2.0745586The first one is the standart MVRC option. Second one is the MVRC_Fast option with same car. I think this is a serious thing since i often use the fast option for quick results.
Come on! We're all late...I've made my first simulation today after putting together a car in 3 days!Team_Bart wrote: ↑Fri Aug 09, 2019 7:41 pmHi Guys, I jus read the email about the new season. Nice to see you managed to design a complete set of rules! I hope it will attract a lot of new competitors because I think this is one of the best engineering competitions which is accessibele for anyone. You can really learn a lot skills in engineering and aerodynamics in specific.
Unfortunately I decided to not join (the beginning of) this season. Last season I was really enjoying the competition and I learned a lot. The main reason is that I have too little time to run the simulations on my laptop. I hoped to find a solution for this but I still have none
Good luck all with the development of your cars, I will keep follow the competition and probably I can join later.
I quit that one around 1250. Thats why i posted the results at 1200. I completed 3 sims at fast settings, i ended up with these results:variante wrote: ↑Fri Aug 09, 2019 10:21 pmWhy "Time = 1200"? Iterations in "fast" go up to 2000; in "normal" even more, probably. Given the different settings between "normal" and "fast", i don't think that residuals compare. Let them converge and then lets see what happens.Ft5fTL wrote: ↑Fri Aug 09, 2019 7:27 pmI finished my first couple of cfd's with the new software and my new cpu. There is some significant difference on the results that i got from different cfd options.
I've just completed my first simulation in "fast" and everything seems right.
BTW if anyone has similar info about fast and normal, please share because i probably won't have the time to do any comparison.
Cd: 1.1227065555, Cl: -0.3831973513, Cl(f): 1.7312270195, Cl(r): -2.1144243705, CoP: 18.761
Cd: 1.1888227472, Cl: -1.7330100288, Cl/Cd: -1.4577530863, Cl(f): -1.7699407171, Cl(r): 0.0369306882, CoP: -0.072
Cd: 1.2144504931, Cl: -1.8959802335, Cl/Cd: -1.5611836335, Cl(f): -1.7225041266, Cl(r): -0.1734761067, CoP: 0.311
60803 wall MVRC_bool_reduced_patch60794 60804 wall MVRC_bool_reduced_patch60795 60805 wall MVRC_bool_reduced_patch60796 60806 wall MVRC_bool_reduced_patch60797It happens with the provided parts I decimated using magics to reduce size.
