That's true. The nature of the camber is also important. But you must concede that Merc's true pace in Austria this year was greatly hampered by their PU overheating issues.godlameroso wrote: ↑Mon Aug 26, 2019 1:37 pmIt's one thing to have elevation change, another to combine elevation change with corners. Sector 3 in Austria for example, is a series of downhill right hand turns.zibby43 wrote: ↑Sat Aug 24, 2019 8:47 pmMerc's advantage in slow-speed corners goes beyond downforce. It has to do with their suspension kinematics and tire temperature management.godlameroso wrote: ↑Sat Aug 24, 2019 1:58 pmThe bus stop hair pin is too slow for it to require downforce. You only need downforce for sector 2. One thing I've noticed is the Mercedes isn't great if the track has a lot of elevation change combined with corners.
What tracks would those be?
In terms of the circuits that have been raced on so far this year, Austria is the only one I can think of where they didn't perform well this year. And that had to do with the heat and the altitude of the entire track itself.
Austria has 63.5m worth of elevation change over the course of a lap.
Monaco has a surprising 42m, and Hungary 34.7m. Mercedes has done well at both of those tracks this year.
Monaco:
https://www.formula1.com/content/fom-we ... 306021.jpg
Hungary:
https://www.formula1.com/content/fom-we ... 304503.jpg
Spa has the greatest elevation change over the course of a lap of any circuit on the calendar.
https://www.formula1.com/content/fom-we ... 301894.jpg
Yeah, that's what they say.zibby43 wrote: ↑Mon Aug 26, 2019 8:37 pmThat's true. The nature of the camber is also important. But you must concede that Merc's true pace in Austria this year was greatly hampered by their PU overheating issues.godlameroso wrote: ↑Mon Aug 26, 2019 1:37 pmIt's one thing to have elevation change, another to combine elevation change with corners. Sector 3 in Austria for example, is a series of downhill right hand turns.zibby43 wrote: ↑Sat Aug 24, 2019 8:47 pm
Monaco:
Hungary:
I don't want to put words in your mouth, but are you implying that they didn't have PU overheating issues, and they merely decided to lift and coast 400m per lap in the race (costing them, at minimum, 0.5s/lap) for fun?
Have a great timeStarscreamer wrote: ↑Tue Aug 27, 2019 6:31 amTomorrow I'am going to Belgium![]()
With my father and father-in-law.
Hope for a nice weekend![]()
Not really, the heat management doesn't kick in for the ''all-out'' Q-laps - only during the race.yelistener wrote: ↑Tue Aug 27, 2019 5:59 amBoth RB and Ferrari managed to beat their 2018 Q3 (by about 0.4s) at the Red Bull ring. Mercedes on the other hand couldn't. It's obvious that Mercedes suffered the unusual heat a lot more than others do.
The requirement to open up the bodywork to allow for the in-race cooling needs caused the aero to be less than optimal. You race what you qualify, i.e. you can't change the bodywork between qualifying and the race, so they carried the inferior aero through both qualifying and the race. Qualifying was affected as much as the race was.dxpetrov wrote: ↑Tue Aug 27, 2019 9:28 amNot really, the heat management doesn't kick in for the ''all-out'' Q-laps - only during the race.yelistener wrote: ↑Tue Aug 27, 2019 5:59 amBoth RB and Ferrari managed to beat their 2018 Q3 (by about 0.4s) at the Red Bull ring. Mercedes on the other hand couldn't. It's obvious that Mercedes suffered the unusual heat a lot more than others do.
Again, completely and utterly wrong again. The ''lift-and-coast'' procedure, that mostly affects the pace during the race, is not at all present during the qualifications.Just_a_fan wrote: ↑Tue Aug 27, 2019 10:08 amThe requirement to open up the bodywork to allow for the in-race cooling needs caused the aero to be less than optimal. You race what you qualify, i.e. you can't change the bodywork between qualifying and the race, so they carried the inferior aero through both qualifying and the race. Qualifying was affected as much as the race was.dxpetrov wrote: ↑Tue Aug 27, 2019 9:28 amNot really, the heat management doesn't kick in for the ''all-out'' Q-laps - only during the race.yelistener wrote: ↑Tue Aug 27, 2019 5:59 amBoth RB and Ferrari managed to beat their 2018 Q3 (by about 0.4s) at the Red Bull ring. Mercedes on the other hand couldn't. It's obvious that Mercedes suffered the unusual heat a lot more than others do.
If their simulation data shows that temps would go out of the roof if the ultimate Q3 mode (Strat 2) is used, then they would not turn that mode on in Q3. It would naturally limit their ability to perform at their best in Q3.dxpetrov wrote: ↑Tue Aug 27, 2019 10:28 amAgain, completely and utterly wrong again. The ''lift-and-coast'' procedure, that mostly affects the pace during the race, is not at all present during the qualifications.Just_a_fan wrote: ↑Tue Aug 27, 2019 10:08 amThe requirement to open up the bodywork to allow for the in-race cooling needs caused the aero to be less than optimal. You race what you qualify, i.e. you can't change the bodywork between qualifying and the race, so they carried the inferior aero through both qualifying and the race. Qualifying was affected as much as the race was.
I'm not talking here out my ar**. Teams had actually confirmed that heat built-up is not so much of an issue during Q-runs. They only have to do one ''full-on'' lap there. Not sure why do we need to beat up on this so much. It's basic logic as well.GPR -A wrote: ↑Tue Aug 27, 2019 11:22 amIf their simulation data shows that temps would go out of the roof if the ultimate Q3 mode (Strat 2) is used, then they would not turn that mode on in Q3. It would naturally limit their ability to perform at their best in Q3.dxpetrov wrote: ↑Tue Aug 27, 2019 10:28 amAgain, completely and utterly wrong again. The ''lift-and-coast'' procedure, that mostly affects the pace during the race, is not at all present during the qualifications.Just_a_fan wrote: ↑Tue Aug 27, 2019 10:08 am
Maybe you guys are talking past one another. The lift and coast is during the race. But the aero preparations Mercedes made during Qualifying where they had to open up the body work beyond its optimal design was, Mercedes then went on to say that even that wasn't enough so they had to lift and coast. One problem (cooling) then leads to overheating during the race because Mercedes under estimated the level of cooling required.dxpetrov wrote: ↑Tue Aug 27, 2019 12:04 pmI'm not talking here out my ar**. Teams had actually confirmed that heat built-up is not so much of an issue during Q-runs. They only have to do one ''full-on'' lap there. Not sure why do we need to beat up on this so much. It's basic logic as well.
Congratulations, you're assigned the local weatherman job for the weekend!Starscreamer wrote: ↑Tue Aug 27, 2019 6:31 amTomorrow I'am going to Belgium![]()
