Page 1 of 2
2008 CDG Concept - CFD Analysis
Posted: 20 Jun 2006, 02:57
by miqi23
Couldnt find any thread on this, actually I did not bother looking for it ;)
Anyways I should upload more images on this. Here is a starter.
[IMG:1209:711]http://img132.imageshack.us/img132/6355 ... cal4rz.jpg[/img]
Thanks
Posted: 20 Jun 2006, 12:51
by miqi23
Here is another one, 4 vortices, twice the amount of vortex drag in 2008 compared to now.
[IMG:1209:711]http://img136.imageshack.us/img136/3369 ... al25jk.jpg[/img]
Posted: 20 Jun 2006, 13:01
by kilcoo316
Have you modelled the diffuser?
Could you give details on the upwash in the wake of the car, from the ground to wheel height?
Posted: 20 Jun 2006, 13:48
by ackzsel
I don't see any influence from the tires to the airflow. Is that because that influence is very insignificant or wheren't the tires rolling in your simulation?
Posted: 20 Jun 2006, 15:10
by miqi23
Actually I have not modelled the diffuser correctly since my aim was to study the effects of wheel spin on wing performance.
The current wake structure you are seeing is slightly more than half a car length behind the car. If you add the diffuser then add a little bit of more wake but I can tell you that it is still much better than what we have now i.e. 2006 season.
I shall upload few more screen shots showing the comparison between 2006 and 2008 :wink:
Thanks
P.S. Yes the tire is modelled as spinning! The streamlines you are seeing in the second image are way above the tire hence you are not seeing any sort of effect.
Posted: 20 Jun 2006, 15:41
by kilcoo316
Sorry for appearing so inquisitive, but what software did you use? Fluent/Star/CFX?
What format is the CAD geometry in? [I'd love a copy if I could use it :) ]
I'm wondering how significant the effects of the diffuser will be - in my own opinion, the majority of the current problem stems from the diffuser, not the rear wing [I think its too high above the ground to cause upwash effects to the degree suffered in F1 - for the same reason I'm quite skeptical of the benefits the CDG rear wing is supposed to bring]. But maybe I can sneak a job onto the supercomputer at work when no-one is looking to see what it does :lol: :twisted:
Posted: 20 Jun 2006, 16:03
by flynfrog
you should stick a car behind it then go take a nap for a few hours while it converges
in about a month they should have the super computer up and running here and i could do some areo runs
Posted: 20 Jun 2006, 16:52
by dumrick
Back to my personal question for some months though: you are moddeling the new wings with a similar carbody to the one currently used to maximize the central rear wing efficiency... what tells you (and FIA...) that the bodyshape won't be changed?
If I had no central rear wing to worry about its efficiency, I would try a wedge-shaped upper carbody or some other resource to get some downforce from that area. That can make a lot dirtier trail than the one you and the FIA are estimating...
Just look at current shapes now: flip-ups and winglets in the edges of the body, where they don't affect the airstream for the rear wing. With CGD wings, these air-dirtying devices (as possible by regulations) will move to the centre of the body and could make the whole decision of implementing the CGD wings look ridiculous.
Posted: 20 Jun 2006, 17:33
by miqi23
The change from 2007 to 2008 is quite significant. You should appreciate that a lot of changes has been made to the current regulations, however to successfully blend your self in the 2008 season it is best to analyse what can be used from the current regulations to minimise the time required to design a new car.
The car you are seeing in the images are actually a modified 2006 car to meet the 2008 regulations. As I said minimum changes and still meet the 2008 regulations! However, the new rules has opened a new door for further research in aerodynamics. The following image is an analysis on the actual car with the diffuser producing the up-wash which is causing a lot of problem nowadays. I did that to study the performance of newly designed rear wing with close proximity to the car.
[IMG:1209:711]http://img97.imageshack.us/img97/4793/2 ... al18ck.jpg[/img]
Kilcoo, the flow solver used for these analysis was Star-CD.
The following shows the streamlines on the 2008 car, its pretty much apparent that it will be effective. As far as the flip-ups is concerned to cause dirty air etc, read the rule book 'dumrick', any object causing the airflow to disturb at the rear of the car would not be permitted ;) Simple as that. What ever you do, if they find it working you will be asked to remove it!
[IMG:1209:711]http://img61.imageshack.us/img61/9253/2 ... al21dm.jpg[/img]
As I said before, the aim of this study was to study the effect of wheel spin on wing performance since no work has been done on it before.
Thanks.
Posted: 20 Jun 2006, 18:38
by miqi23
flynfrog wrote:you should stick a car behind it then go take a nap for a few hours while it converges
Yes, if you have access to a super computer and can run a job on it then I can send you a CFD file with two cars in a row. Its quite hard for me to sneak in a CFD job on our cray on something we are not working anymore for a while.
Which flow solver would your cluster be using? So that I can generate the mesh in that format.
Many Thanks.
Posted: 20 Jun 2006, 19:27
by flynfrog
i can run it on star cd but i prefer star ccm
we have fluent as well but ive never used it
http://blogs.zdnet.com/emergingtech/index.php?p=235
this will be the computer
and yes you can veiw your results in full immersive 3d
Posted: 20 Jun 2006, 22:56
by Jersey Tom
..sneak in a job on your Cray? Jeez. Where do ya work?
Posted: 20 Jun 2006, 23:23
by zac510
Great visualisations miqi! Thanks.
I would have thought the upwash from the car would be much greater but I realise the upwash from the rear wing elements is not shown.
Posted: 21 Jun 2006, 13:25
by miqi23
flynfrog wrote:i can run it on star cd but i prefer star ccm
Alright then no worries, I should generate a file for both Star-CD and Fluent for you to run. Star-CD is a bit complicated! how about Fluent and I send you a little guide on what to do? I will set every boundary condition in advance (say 200 km/hr) like the simulations, all you need to do is press go or Iterate I should say!
Let me know what you think and most importantly what will be your limit on cell count? So that I generate reasonable mesh.
Oh, how on earth do I transfer you the case file? In case of 10 million cells the least, it generates some thing equal to 500MB!
Thanks.
Posted: 21 Jun 2006, 14:24
by NickT
Excellent thread, pictures and explinations. Thanks Guys.
I have a question: If the rear diffuser was limited to a flate plane at an angle of 15deg starting at the centerline of the rear wheels and finishing where the current version ends, would it have a dramatic redution in downforce and the upwash presented to a following car?
I am thinking here of significantly reducing downforce and upwash under the 2008 regulations.
