Red Bull RB16
Viruzpunk
Viruzpunk
Re: Red Bull RB16
If i m right i didn't see someone mentioning this little tweak :
he talks about it at 2.20 min, we can see it too at 2.00.
This kind of little details which make you proud of the guys, hard workers. =D>
the EDGE
the EDGE
65
Re: Red Bull RB16
Viruzpunk wrote:
Sun Feb 16, 2020 4:30 pm
I’m pretty sure what he is referring to is the feeder for the S-duct, the small slits on the nose at to small and are probably for driver cooling
dxpetrov
dxpetrov
-4
Re: Red Bull RB16
Great video! Would be even better if it was made in English! 😂
the EDGE
the EDGE
65
Re: Red Bull RB16
Mark Priestly on the RB16
lio007
292
Re: Red Bull RB16
bulldog
bulldog
Re: Red Bull RB16
base_1000 wrote:
Fri Feb 14, 2020 8:47 am
Made some comparison gifs of the RB15 & RB16. Matched up & brightened.
Full:
https://cdn.imgchest.com/files/x84apcvow4l.gif
Close-ups:
Rear wing, rear-suspension & bodywork
https://cdn.imgchest.com/files/ak46acgep7z.gif
Sidepod & mirrors
https://cdn.imgchest.com/files/epyvdcno5yk.gif
Bargeboard & floor
https://cdn.imgchest.com/files/j6yxkcqo57w.gif
Front-suspension & brake-duct
https://cdn.imgchest.com/files/8b49zcvojyw.gif
Thanks.
Nice comparsion.
SiLo
103
Re: Red Bull RB16
Looks like they have beefed up the upper wishbone and made the lower one smaller this year, the reverse of last year. I assume trying to get cleaner air lower down running along the barge-boards and top of the floor.
Felipe Baby!
pierrre
pierrre
55
Re: Red Bull RB16
here is a piece on the red bull racing rb16
thanks for the approval
Bandit1216
19
Re: Red Bull RB16
Bandit1216 wrote:
Thu Feb 13, 2020 12:45 pm
Is the steering rod inside the front-part lower wishbone? I can't see a separate steering rod.
Nobody?
SiLo
103
Re: Red Bull RB16
Bandit1216 wrote:
Tue Feb 18, 2020 10:50 am
Nobody?
Most teams do this except williams I think.
Felipe Baby!
scarbs
scarbs
391
Re: Red Bull RB16
Nobody?
It's a unique set up, the rack is midway between the top and bottom wishbones, but placed rearwards, nearer the front axle line than the front bulkhead. The track rod then reaches backwards to pivot on the upright behind the front axle line. It even passes behind the pushrod.
Easier to create an Ackerman setup, to turn the inner wheel and lower its ride height via the POU geometry
Bandit1216
19
Re: Red Bull RB16
scarbs wrote:
Tue Feb 18, 2020 5:18 pm
Nobody?
Hmmm. Don’t quite grasp it. I have seen Williams is the only team still putting a steering rod in mid airflow, which seems less efficient to me. I thougt all other teams place the rod in front of the lower or higer wishbone, and integrade the teardrop shape as both rods being one teardrop shape. But with the RB16 I can’t see any separate steering piece. I hope my English is suffient to get what I mean.
pierrre
pierrre
55
Re: Red Bull RB16
tie rod is outside but not visible on earlier photos...it has been corrected. the tie rod ironically is on the aft position which is quite radical when comparing to the other cars and last years RB15. suspect this is done to move the tie rod closer to the bargeboards and influence aerodynamically as the tie rods is pretty much shaped like an aero element that is at an angle rather than some of the other cars that have their tie rod merely more streamlined instead
the tie rods are visible behind the push rods and those push rods are normally designed from an engineering perpective to the center line of the where the front wheel torque is
scarbs
scarbs
391
Re: Red Bull RB16
Explained more deeply and with images on twitter here.
Re: Red Bull RB16
So did they design it to more precisely control front ride height during the toe curve? Also interesting is the shape of the track rod.
