Ferrari SF1000
RZS10
359
Re: Ferrari SF1000
The scaling in that comparison is off
edit: the coloured rings on the tyres don't line up, if you don't know what to look for
bluechris
Re: Ferrari SF1000
The seating position also is higher in the Ferrari? or Vettel is so much taller?
mmred
mmred
-3
Re: Ferrari SF1000
If you check, the part of helmet that Is out of the halo protection Is the same. the colour and the scaling makes some trick here
Apart from that the real difference May Be 1 cm
Re: Ferrari SF1000
SiLo
130
Re: Ferrari SF1000
Need to remember that whilst Mercedes may have the lowest rake angle, having the longest car means the diffuser can be the same height from the floor. This means they are technically expanding more area just at a less aggressive angle.
Felipe Baby!
nico5
Re: Ferrari SF1000
SiLo wrote:
05 Mar 2020, 00:23
But at the same time, while it's true they might be at the same height, having a steeper angle allows for a more aggressive upward expansion behind the diffuser. You can compensate by having a steeper diffuser angle, but I'm pretty sure that also comes with an increase in rear sensibility and flow separation.
SiLo
130
Re: Ferrari SF1000
nico5 wrote:
05 Mar 2020, 00:39
SiLo wrote:
05 Mar 2020, 00:23
Correct it's harder to seal consistently. So far it seems Mercedes potentially more stable route has made the car more drivable.
Felipe Baby!
f1316
f1316
78
Re: Ferrari SF1000
So they’re both the SF1000 but the left is with the test 2 update?
sucof
Re: Ferrari SF1000
So the difference between the old and actual car is that the mechanics now wearing helmets?
:D
SiLo
130
Re: Ferrari SF1000
f1316 wrote:
05 Mar 2020, 00:46
No that's the SF90 on the left.
Felipe Baby!
LM10
LM10
120
Re: Ferrari SF1000
f1316 wrote:
05 Mar 2020, 00:46
Left one is SF90. While at first sight one might think that they’re fairly similar in packaging, a closer look shows that the SF1000 is clearly slimmer in sidepod area. Actually it’s slimmer from sidepod area up until the coke bottle area. The coke bottle of the SF90 seems to be tighter, but it’s just an optical illusion in my opinion as the engine cover of the SF90 is fairly brighter so it’s curves towards coke bottle area get narrower more aggressively.
siskue2005
70
Re: Ferrari SF1000
LM10 wrote:
05 Mar 2020, 01:05
f1316 wrote:
05 Mar 2020, 00:46
After superimposing and scaling and aligning both images shows that the SF1000 is same at the sidepods levels but fatter in the coke bottle region (or am i seeing things?)
f1316
f1316
78
Re: Ferrari SF1000
siskue2005 wrote:
05 Mar 2020, 01:36
LM10 wrote:
05 Mar 2020, 01:05
f1316 wrote:
05 Mar 2020, 00:46
https://serving.photos.photobox.com/751 ... 7f4d1f.jpg
https://i.imgur.com/RBE6sDO.jpg
Yeah, I mean, visual impressions from above are that the one on the left is tighter.
I think this may derive from the shape though: from the side you can see how big the undercut is under the coke bottle on the new car, and this seems to be where the packaging focus is.
Vunnible
Vunnible
Re: Ferrari SF1000
If you look at the widest part of the side pod, more of the floor is visible on the SF1000. Since the floor width hasn’t changed, the SF1000 is indeed slimmer.
nico5
Re: Ferrari SF1000
siskue2005 wrote:
05 Mar 2020, 01:36
LM10 wrote:
05 Mar 2020, 01:05
f1316 wrote:
05 Mar 2020, 00:46
If you're willing to seek some embarrassment, superimpose the Merc :D
