I don’t understand the last item in that list. Unless they mean feedback from the output shaft SS it is used to ensure things like the new part throttle fuel usage constraint.siskue2005 wrote: ↑Fri Sep 04, 2020 5:07 pmThanks for clearing it uphenry wrote: ↑Fri Sep 04, 2020 5:00 pmI’m afraid you’re wrong.siskue2005 wrote: ↑Fri Sep 04, 2020 4:47 pm
The engine mode includes power unit, including ERS deployment and recovery
please correct me if i am wrong
The engine is the ICE.
1.23 Engine
The internal combustion engine including ancillaries and actuator systems necessary for its proper function.
These are the things the so-called ICE mode to be the definition of the following parameters in engine management:
Fuel flow rate
Air volume
Boost pressure
Combustion phasing
Injection times
Switching speed
Fuel temperature
Pressure in the pneumatic valve system, crankcase
oil pressure
Wastegate valve timing and MGU-H working time
Control of the power measured on the output shaft
https://www.auto-motor-und-sport.de/for ... direktive/
I think Wastegate valve timing and MGU-H working time probably refers to anti lag operation. That is MGU-H operation in relation to the ICE rather than the ERS. But I could be completely wrong.
There are 3 other things that are referred to a modes:
ERS modes:
Charge
Neutral
Discharge
PU operation modes, mixing ICE and ERS components, ICE, MGU-K, MGU-H and ES to achieve different power levels ERS energy flows.
For example.
E-boost
Self sustain plus
Self sustain
ICE only
Hot charge
Strategy mode. Selecting which of the PU modes is used at what point on a lap to match the ERS mode and prior to this weekend the overall power level.
I am not sure how all this will knit together under the new rules regime. I would expect attack and defend operations will be softer, since the ICE power variation is now constrained. But what effect this will have on other operations of the PU is difficult to forecast.
