2025/2026 Hybrid Powerunit speculation
Big Tea
99
Re: 2025/2026 Hybrid Powerunit speculation
Surely not fully 'depowering' the engine will have the same effect as if it is still driving the wheels it can recover more energy from them, assuming the 'recovery system' is slowing the car, not using the disks?
saviour stivala
wuzak wrote:
20 Nov 2022, 12:46
saviour stivala wrote:
20 Nov 2022, 12:11
Personally I am certainly convinced that an engine design team leader will know exactly what he is talking about, regardless of what you and others on here believe.
I believe in his interview he explained he doesn't know all about the ERS side of things.
20 Nov 2022, 12:11
Yes. The ‘K’ ‘HARVESTING’ under braking is the same mechanism when lift-and-coasting, essentially engine braking, But apart from the engine braking, which means the engine is as explained elsewhere, is driving the ‘K’, it is during lift and coast driving the ‘K’ free of any ‘IN’ or ‘OUT’ load as both the throttle which activates deploying and the brake pedal, which activates harvesting are not activated – being used.
Why do you think that recovery is activated by the brake pedal?
Certainly deployment is not controlled completely by the throttle pedal - it doesn't always deploy when the throttle is activated.
Deployment ('K'- to - crankshaft is dependent on throttle, if throttle pedal is not being activated there is no deployment by 'K'. Harvesting ('K' - to - 'ES/'H' is dependent on brake pedal, if brake pedal is not being activated there is no harvesting by 'K'. But as explained before, In both cases as long as the engine is running the 'K' is riding along on the crankshaft.
Why do I say that recovery is activated by the brake pedal. Because 'K' converts kinetic energy from the brakes that would otherwise have gone to waste into electrical energy. If electrical energy is harvested by the 'K' when the brakes are not activated, that harvesting is being done by using fuel (engine running 'K'). As I said, am more than convinced that the RBPT engineer known exactly what he was talking about.
aleks_ader
90
Well he is developing combustion chamber and test benchers. So for him any ERS knowledge doesn't change anything. I would not exclude loopholes in engine mapping in that area.
saviour stivala
aleks_ader wrote:
20 Nov 2022, 17:55
So we are here to believe that a man of the caliber of a formula one engine design team leader engineer went into an interview with one of the top technical magazines and he was pushing out opinions which are out of his competence. PLEASE count me out of this on here subject as too much is too much to stomach.
444
20 Nov 2022, 17:38
In lift-and-coast the engine is making the same amount of power that it is when the brakes are activated.
saviour stivala
The only possible use of the MGU-K to charge the ES or help the ‘H’ by burning fuel (‘K’ run by engine) will still involve the activation of the brake and throttle pedals at the same time.
620
21 Nov 2022, 09:46
the driver lifts off the accelerator but doesn't touch the brake pedal .....
the ICE gets no fuel .....
in such generating the K is reducing the car speed & PU rpm etc - turning unwanted KE into electrical energy
this isn't 'burning fuel' ....
so it isn't 'engine running the K'
sorry if this is repetitious
saviour stivala
Tommy Cookers wrote:
21 Nov 2022, 13:19
21 Nov 2022, 09:46
No problem with being 'repetitious' at least with me.
Fully in agreement that the engine gets no fuel when driver lifts accelerator, but unless he activates brake pedal there will be no ‘K’ harvesting.
620
21 Nov 2022, 13:38
21 Nov 2022, 09:46
so ....
accelerator-off a (generating) MGU-K isn't run by the engine
saviour stivala
‘’So …. Accelerator -off a (generating) MGU-K isn’t run by the engine”.
Unless one prefers overcomplicating simple things, ‘accelerator-off’/accelerator lifting, will not switch MGU-K to harvesting mode.
In factual terms a ‘generating’ MGU-K is run by the engine crankshaft.
A deploying MGU-K is trying to run the engine crankshaft.
A non generating and a non deploying MGU-K is getting a ride on the engine crankshaft, as long as the engine is rotating.
aleks_ader
90
20 Nov 2022, 21:52
aleks_ader wrote:
20 Nov 2022, 17:55
Well yeah. I mean he emphasised that he is NO ERS lead. So holistically speaking it does not change his part of turbo V6 development anyway.
ERSK running under braking or under gas load does not change how combustion system works. So early in development and research it does not even matter. That is no MGUH integration like in previous years. vehicle integration and harmonics are for other departments to sort it up.
444
This full power deployment map is interesting
31.3s at full throttle.
28.5s at maximum power.
saviour stivala
As the one before it, the video is also interesting, so also thanks for the link. This second different track video makes things extra interesting because of the different levels of maximum power deployed per lap (different levels of maximum power) is clearly depicted between the two tracks. The difference in maximum power output possibly produced and deployed by the power unit is at a higher level (waste-gate/s open - ''free-load-mode" - with 'H' and 'k' sharing 'ES' power in the first video), while in the second Monaco video the maximum power output deployed per lap is at a lower maximum level - ''ERS BOOST'' depicting full 'K' power deployment only as an addition to what the ICE was producing with normal boost.
Hoffman900
163
wuzak wrote:
22 Nov 2022, 00:30
What's the resolution on this data and how is it being measured?
444
Hoffman900 wrote:
22 Nov 2022, 06:05
wuzak wrote:
22 Nov 2022, 00:30
It appears he is using frequency analysis from the exhaust mic to determine when the car is at full throttle and when the wastegates are open.
I couldn't guess what the resolution of the data is.
Post Reply
