2021 Red Bull Racing F1 Team
siskue2005
70
Alexf1 wrote:
Tue Nov 23, 2021 2:00 pm
siskue2005 wrote:
Tue Nov 23, 2021 1:59 pm
Alexf1 wrote:
Tue Nov 23, 2021 1:56 pm
Technical enough?:
Not technical enough! :lol: '
That is light shadow
its been discussed here in the technical car section
viewtopic.php?f=12&t=29672&start=1260
Sure it is...
What a great technical come back, I am convinced #-o
Here is the actual high resolution video of the same thing which is reduced in quality and compressed to hide the fact that it is sun light which is shining through it.
You can read more here
WaikeCU
siskue2005 wrote:
Tue Nov 23, 2021 12:56 pm
Alexf1 wrote:
Tue Nov 23, 2021 12:02 pm
And gone was Ham insane top speed advantage in Qatar even though RB was running the Monaco barn door. If only the FIA would have told Merc after Brazil qualifying to replace the torque screws on the lower RW panel with fixation screws. We wouldn't have seen him coming theough the field like that in sprint and main race. 3rd in main race would have been the highest position he could have reached. Yes the engine is better and yes the car was improved but the stalling of the RW was key for all the overtakes. To hear Toto claim "it's against us, Lewis has experienced it all his life and now we do too" after the race was very misplaced. They were very very lucky to get away with that last chance for the WDC. Just my 2 cents..
I thought this was a technical forum! Please read up on what is actually happening than listening to gaslighting from Horner
See the quotes below from top speed analysis by Mark Hughes
zibby43 wrote:
Sat Nov 20, 2021 9:04 pm
Same wing.
Mark Hughes destroys the RBR theories here:
https://the-race.com/formula-1/mark-hug ... ll-claims/
Excerpt:
Technical enough?:
It's incredible how much detail you can see on a 120p video nowadays. I'm amazed with Twitter ngl =D>
aral
aral
26
For the umpteenth time, could you please keep the forum on topic....the RBR F1 TEAM. Discuss Merc and Hamilton on the relevant fora.
WaikeCU
Are they flying straight to Jeddah after Qatar since there's a week until the next race?
Wondering if RB will solve the DRS flapping issue next race.
siskue2005
70
WaikeCU wrote:
Tue Nov 23, 2021 2:16 pm
Even if the team move to Jeddah, the teams in UK can correct the wing and send it to them before the race start
Revs84
Revs84
siskue2005 wrote:
Tue Nov 23, 2021 2:25 pm
Horner confirmed they will. And I sure hope they do, since the RB16B seems to work much better with the spoon wing they were supposed to use in Qatar.
WaikeCU
WaikeCU wrote:
Tue Nov 23, 2021 2:03 pm
What?! Are you for real??? What kind of reason is that?? :x
Revs84 wrote:
Tue Nov 23, 2021 4:36 pm
Where have they ran the spoon wing before? Any high speed GP's they ran this wing?
Nathanael F1
Nathanael F1
Spa and Monza, I think.
zibby43
zibby43
612
Someone correct me if I’m wrong, but my understanding is that the problem is with the robustness of the actuator, and re-designing that part would require a token.
My name is Jos and I like to beat my son. In racing.
El Scorchio
zibby43 wrote:
Tue Nov 23, 2021 8:58 pm
have they ever had issues with the actuator in the past, or is it a new thing? Seems odd that it's only happening now. Would any other changes in design of that part of the car influence how it works and indeed if it works?
dans79
260
That's correct, it's a 1 token change (see page 124).
https://www.fia.com/sites/default/files ... -06-28.pdf
193 103 103 7
dans79
260
El Scorchio wrote:
Tue Nov 23, 2021 9:03 pm
It happened last year as well!
https://www.formula1.com/en/latest/vide ... 95727.html
193 103 103 7
siskue2005
70
So they cannot change it for the last 2 races?
dans79
260
siskue2005 wrote:
Tue Nov 23, 2021 9:20 pm
22.7.4 b is the only rule that I'm aware of that would allow them to revert to a previous revision.
In the case an HC component has been revised either through the use of tokens, or
before its homologation date but does not meet the Competitors expectations, it will
be permitted to revert back to the original specification of this HC component within
five Competitions from its first introduction. Any tokens used may not be re-used for
other purposes, and the new specification must be discarded.
However the freeze date for DRS components was the middle of last season. Thus unless they spent a token in the last 5 races to modify it, they are stuck with it till the end of the season!
edit: it's worth noting the Homologation rules have these 2 extra bits of information.
possible to homologate 2 options for different levels of downforce
attached to the rear wing flap. linkages to achieve different kinematic characteristics are allowed
193 103 103 7
Aesop
Aesop
It's fixed in time for Jeddah apparantly:
https://www.gpblog.com/en/news/99705/re ... l-gps.html
